Author Topic: JIDX CW contest run from 4/09 at 0700 to 4/10 at 1300Z  (Read 70 times)
« on: April 05, 2022, 11:28:31 PM »
The JIDX cw contest is this coming weekend. Japan works the world and the world works only Japan.
http://www.jidx.org/
Rules   http://www.jidx.org/jidxrule-e.html
5. POINTS:
   Only contacts between JA and DX(+/MM) are worth contest points.
(DX-DX, DX-/MM or JA-JA contacts are no point and no multi)
      1.8MHz................. 4pts
      3.5/3.8MHz ............ 2 points
      7MHz, 14MHz and 21MHz.. 1 point
      28MHz.................. 2 Points
The same station may be worked only once per band.
No cross mode, cross band nor repeater contacts are allowed.
6. MULTIPLIER:
JAs   :The number of different DXCC entity (except JD1) and CQ
       Zone worked on each band.
       QSO with /MM stations is worth for Point and Zone multi but
       no Entity multi.
Others:The number of different Japanese Prefecture plus Ogasawara
       Is.(JD1), Minami-Torishima Is.(JD1) and Okino-Torishima Is.
       worked on each band. Maximum of 50 (See the jidxmult.lst) per band.
