Author Topic: FT891 computer programming. Is it a normal USB with RT Systems?  (Read 145 times)
N1AUP
Can I use a normal USB cable with FT891 and RT Systems or do I have to buy their cable?
Thanks
WA9AFM
Re: FT891 computer programming. Is it a normal USB with RT Systems?
« Reply #1 on: April 20, 2022, 05:26:06 AM »
You have to use their cable, but if the 891 has an SD slot, your would only need the software.
N1AUP
« Reply #2 on: April 21, 2022, 10:24:54 AM »
Just talked to RT Systems.  On the 891, you can use a standard USB cable.  You do not have to use one of theirs, at least for this particular radio.
Other models are not the same, but for the 891, you're good to go.
KU3X
« Reply #3 on: April 21, 2022, 12:20:41 PM »
I have an FT991A and I took the USB cable from my printer and used it, without issues, with the RT software and my radio. The same for my TS 590SG.
Barry
