There are two considerations regarding RG-174.
Electrically, there is about 0.2 dB matched loss per foot on 70 cm and about 0.11 dB matched loss per foot on 2 meters. The actual loss varies by the grade and manufacturer of the coax. So if you keep the length of the RG-174 relatively short, say 2 to 3 feet, the losses are not too bad if your SWR at the antenna is low.
Mechanically, RG-174 is very thin and more easily damaged from flexing and pinching forces. If you need to thread it through very small holes, then you need to put on your own connectors. Crimp style connectors, using the proper tools, are the only way to go on this cable as the center dielectric is easily melted from soldering.
