Author Topic: FT8 / Auto Logging / Help  (Read 220 times)
NN2X
« on: May 08, 2022, 02:51:22 PM »
Hi Fellow Hams
I am trying to set up a Auto logging system when I am using FT8...(WSJT X)...
I tried using Python along with the special scrip (File), I was not successful (One point, when I down loaded the Script for the QRZ, it looked like scrambled letters...(From Python)
Any help would be most appreciated!
DE NN2X / Tom
NA4M
Re: FT8 / Auto Logging / Help
« Reply #1 on: May 08, 2022, 04:51:07 PM »
Not sure if this is what you might be looking for but with all due respect why reinvent the wheel?
WSJT-X will auto log to DXLab's DXKeeper logging program using JTAlert software.
Been happy user of above setup for long time.
« Last Edit: May 08, 2022, 04:57:33 PM by NA4M »
KF6QEX
« Reply #2 on: May 09, 2022, 03:26:35 AM »
I'm using gridtracker ( https://gridtracker.org )  which made using WSJT-X a lot more fun for me and it also happens to be able to log contacts to  LOTW, QRZ, LOG4OM,PSKReporter, ClubLog,HRDLOG,eqsl,N1MM,N3FJP, DXKeeper and HRD Logbook.
sdrawkcab daer tseb si txet sihT
« Reply #3 on: May 09, 2022, 06:33:54 AM »
Same here. JTalert commands DXkeeper to auto log to LOTW and others it you desire.
NN2X
« Reply #4 on: May 09, 2022, 06:26:57 PM »
Thanks I will use JTAlert (The feature I need is auto down load contacts to QRZ)...
Thanks again
