Author Topic: Antenna suggestions for BMW X3  (Read 177 times)
K7AAT
« on: May 19, 2022, 06:45:13 PM »
Looking for antenna suggestions for late model BMW X3.  No holes,   No mag mounts, and no on-glass antennas.   With those limitations, what has worked for other X3 owners?  VHF/UHF.
Re: Antenna suggestions for BMW X3
« Reply #1 on: May 20, 2022, 07:35:36 AM »
Looks like you're down to a trunk lip mount on the hood or rear hatch.  Maybe something affixed to that "visor" on the rear hatch?
K7AAT
« Reply #2 on: May 20, 2022, 08:06:09 AM »
Yes, Mark, that seems to be my choices.  Likely a TM8 trunk lip mount on the hood.   Much as I would hate to drill a couple small out-of-sight holes for a diamond mount near the rear visor, that could be a consideration.  Was hoping to see a reply from someone who may have gone this route....   has benefits as radio could be mounted in the rear since that is where the battery is located....
K4CQO
« Reply #3 on: May 21, 2022, 07:36:33 AM »
Just a question, why can't you use a thru glass mount on the rear window, on one of the rear back windows.
K7AAT
« Reply #4 on: May 21, 2022, 08:27:15 AM »
Deep tint in glass affects through glass RF coupling.
K7AAT
« Reply #5 on: May 21, 2022, 08:30:43 AM »
After a further examination of this vehicle I am wondering if there is an antenna mount that could clamp to the roof rails on this vehicle.....
K6LCS
    • Clint's Stuff
« Reply #6 on: May 30, 2022, 06:09:54 PM »
Roof rack mount? Yes. But you loose your roof rack for carrying stuff.
Never mount an antenna on the hood/front fender. No professional commercial radio system installer will advise you to do that.
Here's a very good antenna system - for your rear-driver's side door, if the edge thickness allowd. Mount so that at least one-half of the whip clears the roofline Along upright edge or top), and you will have  hard-to-beat 2m/440 performance.
Clint Bradford, K6LCS
AMSAT Ambassador, ARRL Affiliated Club Coordinator
http://www.work-sat.com
909-999-SATS
