Author Topic: Direct conversion receive  (Read 402 times)
KD0LQD
« on: May 21, 2022, 06:53:39 AM »
It’s my understanding that a superheterodyne is far more selective than a direct conversion radio.  With that in mind I’m confused on why the new icom ic-t10 is demanding a $240ish price tag.  Am I missing something?  I don’t want to bash a brand but… someone help me out here.
N7EKU
Re: Direct conversion receive
« Reply #1 on: May 21, 2022, 01:10:10 PM »
Hi,
I don't think you can make an assumption like that since it depends on so many things.  Maybe check this out:  https://www.onallbands.com/superheterodyne-sdr-hybrid-sdr-which-is-best%EF%BB%BF/
Mark -- N7EKU/VE3
KD0LQD
« Reply #2 on: May 21, 2022, 02:32:57 PM »
Thanks!
Hi,
KM3F
« Reply #3 on: May 21, 2022, 03:04:57 PM »
I now have some observation experience between the two detection systems.
On an HT with direct conversion, the sensitivity is very high on the unit I have at .1 uv according to specs for the unit. That' well up there with the best.
Observations:
It hears a lot of power line leakage, a lot of trash being from other sources, and systems as I drive around in mobile.
In my area it can sense high powers above the 2m band in business and mobile phone and paging systems.
Case in point; F =152.720. High power was overloading the HT.
To solve the issue, I built a trap for that frequency to the tune of more than -55dB down and solved the problem. The trap was tuned on a VNA then installed in series with the HT to antenna.
The two take aways are the sensitivity and the single conversion.
Both are very good with the absence of interference but can be a problem in that presence.
It seems that more selectivity can be accomplished after the IF is converter to with more filtering but is a function of the radio application, design and what can be tolerated in operation.
I'm not condemning single conversion but understanding what disadvantages there may be in certain circumstances.
I use an HT and small 35 watt Linear amplifier as a mobile radio and love the operation otherwise.
Radio hears better than it gets out for mobile; the Tx audio is first class with a hand mic.
In an HF radio, I would expect more filtering before and after the mixer and the best mixer design to eliminate harmonic mixing results my HT does not have in a small package and price point.
I was lucky to get away with the HT so easy.
The out of band interference is from stations that are allowed to run a lot of power if needed for their service.
Not good for 2m in some areas when you live close by.
« Last Edit: May 21, 2022, 03:11:35 PM by KM3F »
WA3SKN
« Reply #4 on: May 21, 2022, 04:58:59 PM »
The reason for the cost is the MIL specs and weatherproofing... not receiver selectivity.
-Mike.
« Reply #5 on: May 21, 2022, 10:48:08 PM »
The Alinco DJ-VX50 has almost the exact same specs, including the IP67 rating, for $90.
KD0LQD
« Reply #6 on: May 22, 2022, 05:37:50 AM »
It will be good to get my hands on an IC-T10 to get it apart and check it out.  I would love to compare a DJ-VX50 to it too.
