Home
Help
Search
eHam
eHam Forums
HomeBrew
2nd set of contacts on Beede FS1MADC panel meter?
« previous
next »
Pages: [
1
Go Down
Author
Topic: 2nd set of contacts on Beede FS1MADC panel meter? (Read 108 times)
KF6IIU
on:
May 25, 2022, 06:55:16 PM »
I can't post a picture here, but I have obtained a couple of nice 1ma Beede panel meters removed from some medical equipment. Each of these has a second set of smaller screw contacts below the primary main contacts on the back the meter.
The contacts have 0 ohm resistance between them, and about 1/2 ohm resistance to the negative main contact for the meter.
Has anyone seen something like this and have a guess as to what the 2nd set of contacts would be for? They are obviously not for illumination.
Last Edit: May 25, 2022, 07:02:18 PM by KF6IIU
K7MEM
Re: 2nd set of contacts on Beede FS1MADC panel meter?
Reply #1 on:
May 25, 2022, 11:06:45 PM »
Yea, a couple of small pics would be nice. Maybe a link to a couple of pics.
Are you sure they are contacts, or simply screws that hold the movement in the case?
When you measure across the extra contacts, does the meter deflect at all?
Martin - K7MEM
http://www.k7mem.com
KD0REQ
Reply #2 on:
May 26, 2022, 12:33:38 PM »
second the notion that those screws hold the movement into the case, I've seen it before on a meter I had to relabel the scale on.
KF6IIU
Reply #3 on:
May 29, 2022, 02:01:56 PM »
Thanks, I think you are right. Loosening the screws causes the insides of the meter to come loose.
They have a lockwasher and a fiber washer bewteen the lockwasher and the case, but I think they are structural.
Pages: [
1
Go Up
« previous
next »
eHam
eHam Forums
HomeBrew
