Author Topic: Yaesu Repair Recommendations  (Read 402 times)
K4OR
« on: May 29, 2022, 09:10:58 AM »
Good Day,
I'm looking for recommendations on a repair facility for a Yaesu FT-2000 transceiver. The "MOX" switch failed and needs to be replaced. I have read many negative comments regarding the Yaesu repair facility on the west coast and would like to explore other options if there are any.
Thanks in advance & 73,
Garry - K4OR
KB7TT
Re: Yaesu Repair Recommendations
« Reply #1 on: May 29, 2022, 09:24:12 AM »
All front panel switches are mounted on a PCB.  You might look for a front panel replacement board.
AK5B
« Reply #2 on: May 29, 2022, 03:29:59 PM »
Malcolm Technical Service in Washington State.  Give them a call if you still need them...
N8FVJ
« Reply #3 on: May 29, 2022, 05:21:23 PM »
Yaesu repair in CA is fine. I had my FTDX-10 repaired. 3 week turnaround including mail time from FL and back.
N8YX
« Reply #4 on: May 31, 2022, 09:20:57 AM »
I think he retired...but would love to be proven wrong.
« Reply #5 on: June 01, 2022, 08:45:54 AM »
Scott at MTS has retired.  Might want to try Tim Moes at Midwest Technical Services in SD, or Cal at www.hamrepair.com in TX. I think there are a few repair places in Florida and Georgia that work on Yaesu that might be even closer to home for you.  N4ATS comes to mind as one.
K4JJL
« Reply #6 on: June 01, 2022, 01:48:33 PM »
It is possible to replace individual components on circuit boards.
VE7ABC
« Reply #7 on: June 20, 2022, 01:21:06 PM »
I used him twice on a couple of ICOM HF rigs, and would use his services again in a heartbeat.  A gentleman who knew his stuff for sure.  I'm sure that he has retired, deservedly so, but IMHO a great loss to the ham community.
de..Graham
VE7ABC
WB8PFZ
« Reply #8 on: June 22, 2022, 06:03:02 AM »
Not a Yaesu, I had a few bad switches on a Kenwood 930. I found a board on Ebay. Make sure you test the switches before installing. I think out of the 4 2 were good. It solved the problem with the antenna tuner. The Hakko desoldering tool made the job quite easy. One of the best tools I ever purchased.
N5XJT
« Reply #9 on: July 31, 2022, 09:27:43 AM »
Tim Moes @ Midwest Technical Services is a great choice.  See reviews at Eham and they are right on.
