Author Topic: Using Receiver Antenna Output on KWM-2 for SDR  (Read 254 times)
W2JJV
« on: June 22, 2022, 12:05:16 PM »
Going to try out a basic SDR with my KWM-2 to create a waterfall display and to my reading it looks like I can use the KWM-2 REC ANT output for the antenna on the SDR dongle in lieu of adding an SDR T/R switch like the MFJ-1708.  This is my first venture into the world of SDR's and would like to avoid an early catastrophe!  Any guidance on recommended software would be appreciated as well.
It's a new world for me!  Many thanks,
David
K7LZR
Re: Using Receiver Antenna Output on KWM-2 for SDR
« Reply #1 on: June 22, 2022, 03:56:09 PM »
Not unless the RX output on the KWM-2 goes to ground on transmit and I'm pretty sure that it does not. The MFJ-1708 simply grounds the SDR input on TX so no magic in it.
You could perhaps use the amp keying relay of the KWM-2 to key an external relay to do the same thing.....
W2JJV
« Reply #2 on: June 22, 2022, 07:30:08 PM »
Just checked the schematic, the relay does indeed ground out the Rx antenna in transmit mode.  Thanks for the reminder!
73, David
K7LZR
« Reply #3 on: June 22, 2022, 09:11:41 PM »
Very good :). You're all set then. I used a KWM-2 for several years in the 1980s, wonderful rig. Have fun!
