Author Topic: Powermaster 2 meter issues ??  (Read 179 times)
GM1ZVJ
« on: June 25, 2022, 02:17:13 PM »
Hi any ideas on the following issue I am having with my Array Solutions Powermaster 2. All being working well up until today where it started to show the power from my Yaesu Ftdx10 as over 200 watts pep as opposed to the 100 watts it should have been, also swr reading appeared to be lower than usual. Short while later the unit switched itself of. Opened the cover and noticed the mini fuse had blown, replaced this and applied power and the two front mounted leds light up constantly but no screen , plugging the coupler into the headunit and the two leds go out but no screen , nothing …anyone experienced similar ? Unfortunately out of warranty !
GM1ZVJ
Re: Powermaster 2 meter issues ??
« Reply #1 on: June 26, 2022, 05:02:26 AM »
Checked again today and strangely things have changed slightly !!
When powered up the two leds remain permanently lit up and the matrix display shows up on the display, plugging in the coupler and now the headunit keeps powered on ie. Both leds remain lit up , matrix displays but no output / swr readings .
