Author Topic: Vanco SWR-1 Manual  (Read 153 times)
KK6BXO
Vanco SWR-1 Manual
« on: June 27, 2022, 01:33:14 PM »
All, I just purchased a Vanco SWR-1 Meter at a garage sale for $1.  Although it probably qualifies as a Boat Anchor I just couldn't pass it up.  Does anyone have a manual for it that you could scan or take a photo?
Thanks and 73, Maurice. KK6BXO.
WA3SKN
Re: Vanco SWR-1 Manual
« Reply #1 on: June 27, 2022, 02:05:51 PM »
It appears to be a standard "monimatch" design.  Put in between radio and antenna.  Throw switch to forward, key transmitter and adjust for max on meter. Switch to Rev and make meter reading. 3.5----150 MHz with 5% accuracy (maybe).
Test with dummy load for antenna.
-Mike.
WA2CWA
    • ManualMan
« Reply #2 on: June 27, 2022, 02:16:21 PM »
Lafayette, Radio Shack, Midland, and maybe a dozen other companies sold the same meter under their name. Very common.
Pete, wa2cwa
www.manualman.com
« Reply #3 on: June 27, 2022, 02:50:02 PM »
https://www.youtube.com/watch?v=_dGh7p1tZmk
KK6BXO
« Reply #4 on: June 27, 2022, 04:35:23 PM »
Thanks everyone, especially AF5CC for the most appropriate video link.
Just ordered a manual from Manual Man!
73,Maurice KK6BXO
W9AC
« Reply #5 on: June 27, 2022, 07:01:35 PM »
If you're in a rush, I have a .PDF copy of the complete manual I can send you via e-mail. It's for the Lafayette equivalent SWR bridge but it's the same meter with the same instructions.
Paul, W9AC
K4PIH
« Reply #6 on: June 28, 2022, 05:34:39 AM »
I had three of those Vanco SWR meters and sold them at a tailgate meeting. They are designed for CB radio and have I think a 10 watt power limit?
WA2CWA
    • ManualMan
« Reply #7 on: June 28, 2022, 08:21:05 AM »
Actually, these SWR  meters were good for several hundred watts with roughly 1KW PEP max. 100 watt rigs should be no problem
Pete, wa2cwa
www.manualman.com
WA3SKN
« Reply #8 on: June 28, 2022, 01:32:09 PM »
True accuracy varied with frequency.  But you got a good "dip" when sweeping the band.
I still have one... and the box.
-Mike
