Author Topic: Switching digital app problems  (Read 117 times)
KE7NJ
« on: July 12, 2022, 09:29:31 AM »
In the last few days, I'm experiencing issues when I change from JTAlert/WSJT-X to fldigi and vice versa.  When I exit one and start the other, I lose rig control.  It's worked fine in the past as I typically will do a bit of FT-8 and then some BPSK.  After experimenting a bit, it seems that I have to shut the radio (IC-7300) down and turn it back on... then it works fine again.
Since I found a work-around, I'm okay... but still annoying.  It seems to have started after the latest Windows 11 update... don't know if it's related.
Anyone else experiencing this?
Ron
KE7NJ
WW5F
Re: Switching digital app problems
« Reply #1 on: July 12, 2022, 09:57:25 AM »
Yup.  I have to reset my 7410 when switching back and forth between WSJT-X and FLDigi.
K6SDW
« Reply #2 on: July 12, 2022, 10:52:05 AM »
YUP, I too use a 7300 and I notice some apps will take control of the USB port and won't release it properly so a power off/on cycle fixes the problem...an annoyance!
GL/73
KE7NJ
« Reply #3 on: July 12, 2022, 02:34:56 PM »
Ok... I guess I fell better then...  :o
Thanks!
Ron
KE7NJ
K6JH
« Reply #4 on: July 15, 2022, 06:52:55 PM »
Does anyone know if this is fixed if you use an app like WIN4ICOM that can setup multiple pass-through ports to multiple other programs?
Jim K6JH
