Atlas VPN wants money, and don't know if it will solve anything. The Brave browser is said to have it's own VPN, but I'm still blocked from HamApps while using it. But I like the Brave browser, I can visit sites that don't like my ad blocker when using Firefox, Chrome, or Edge. I've been using Dissenter to go to the Fox News site. Brave will also allow me to visit the site.
Laurie, VK3AMA, has been having problems with malicious activity from my IP range. This is from May & June, and the problem is apparently still persisting. These are a few excerpts that he wrote...
"Over many days and from several different addresses in the 35.139.x.x range there was bot activity probing HamSpots generating thousands of 404 html responses in a very short period of time, It was clear there was an attempt to gain unauthorized access to the site.
I have removed the block, so you should now have access again. But if the site probing continues I will be shutting down access from that IP address range again.
Zero response from your ISP.
I removed the firewall block of your ISP IP blocks 34.0.0.0/8 and 35.0.0.0/8. Within 15 minutes of the blocks being lifted the malicious activity resumed. Unfortunately blocking individual IPs as they are detected is not a solution. The abuser changes IP address with each attack."
