Author Topic: ft8 on win 10  (Read 366 times)
W8NSI
    • W8NSI on the Web
Re: ft8 on win 10
« Reply #15 on: August 14, 2022, 06:03:06 AM »
If you suspect a wandering clock, get Dimension4 and install. Never again will your computer clock be the suspect.
Your trouble sounds more like a port problem. M$ updates sometimes mess with them so you have to check that first.
73 de w8nsi Jim
73 de w8nsi/nnn0uzw jim
WA8NVW
Re: ft8 on win 10
« Reply #16 on: September 02, 2022, 12:09:40 PM »
Probably the second most common problem involving Windows 10, WSJTx, and amateur operators is hams setting their (Signalink) USB) audio interface devices to either the DEFAULT or DEFAULT COMM options.  DO NOT DO THAT!!
Default is where Windows sends any unassigned playback audio, instead of going to the computer's speaker, and the default recording device is Microphone, which hears and tries to decode any noise in your shack such as phones, pets, other radios, cursing, etc.
Default Comms is usually grabbed by Zoom, Skype, or other communications software which then randomly will modifies your previous level adjustments and other settings.
G8FXC
Re: ft8 on win 10
« Reply #17 on: September 05, 2022, 03:27:08 AM »
Which can be particularly confusing when you are running FT8... Most of us will leave the RX audio turned up a bit and WSJT-X, taking input from the PC microphone, can hear the received signal - often well enough to decode the strong signals, at least. But any other noise in the shack can interfere with it...
Martin (G8FXC)
