Pages: 1 2 3 [4]   Go Down
Author Topic: Options for mounting a small 2 meter Yagi  (Read 525 times)
K6JH
Re: Options for mounting a small 2 meter Yagi
« Reply #45 on: August 23, 2022, 09:55:09 PM »
At this point I’d almost be tempted to hook my rig up to the cable tv coax (be sure tx is disabled!) and see if I could correlate the noise with something coming off the cable. At least you should be able to confirm that is the source. The noise should be really strong with a direct connection.
Jim K6JH
KK4GMU
« Reply #46 on: August 24, 2022, 11:26:20 AM »
Next week, I was going to drop off a 4-element Cushcraft yagi (already tuned for ~ 145mhz) that you could paint any color you desire and use as long as you needed to (years? decades?), it's my test antenna....old, but in perfect shape (kept in my garage), but this saves me the drive.
John,  KA4WJA
Good thing you didn't. I don't want to push my luck with neighbors or the HOA.  Thanks for the thought.
IC-7100, RSPdx, AT-D878UVII-Plus HT, TGIF Spot
Pages: 1 2 3 [4]   Go Up
