Author Topic: Japanese Solid State Amplifier  (Read 553 times)
« on: July 25, 2022, 09:20:21 PM »
 I have been looking at Bear Electronics amplifiers for probably 8 - 10 years now. If you appreciate "big boy" tube amplifiers (along with great build quality) check out  http://www.bear-el.com/ They are now building solid state amplifiers. If you are interested in running a 8kW SS amplifier on 2 meters here ya go:  http://www.bear-el.com/conby/
 It's probably only a mater of time before they start producing SS amplifiers for HF. All text is in Japanese so you will need to use Google Translate.............Lot's of pretty pictures!!!
        Tom KH0/KC0W
Re: Japanese Solid State Amplifier
« Reply #1 on: July 25, 2022, 09:33:49 PM »
8 KW on 2 meters!  That would be fun!  You should be able to hear your own echos off the moon with that.
WB8PFZ
« Reply #2 on: July 26, 2022, 04:48:50 AM »
There tube amps looked a lot sexier than the solid state amps.
K1KIM
« Reply #3 on: July 26, 2022, 07:57:16 AM »
800W 2 meter amp for 258.000 Yen is not cheap at almost $1900 USD.
But boy are they all pretty cool looking.
« Reply #4 on: July 26, 2022, 11:25:35 AM »
The innards of those tube amps is quite nice. The front panel looks just like the HV power supplies we used in the 1980s.
