JACKIE, PLEASE before you do anything else, replace the old line cord with a new 3-wire cord so you don't kill yourself. A local ham should be able to assist you in getting the wires sorted out correctly. Black connects to the hot lead, white is the 'cold' side, and green goes directly to the chassis. If it pops the breaker when you plug in in the first time, swap the black and white.
