Any of the 48V switching PSU are going to be acoustically noisy if you run them near their max power, even if they have a temperature or load controlled fan. They are designed to be used in places where nobody cares about the noise. If you want something quiet, then either 1) find one without a fan. There are a few, but they are usually $$$ and not as available 2) run them at much less than full load.
I'm currently testing two GE CP3000AC56 supplies running in parallel with load sharing for my 1500 W LDMOS amp. These are 3000W supplies. While a single one will run my amplifier, using two in parallel is much quieter.
The GE is a nice supply and seems RF quiet. One thing I like with GE compared to the Eltek is that I was able to find a complete data sheet for nearly the same model. The datasheet gives all the information on pinout, setting the default voltage, enabling load sharing, I2C programming information, etc.
Tor N4OGW
