Author Topic: New, improved accurate time and timezone info  (Read 291 times)
« on: July 29, 2022, 11:15:12 AM »
The longstanding website, http://time.gov, is much improved.  Have a look.
At a glance you get:
1.  Told what timezone your PC is set to.  This usually is no surprise, but if there is, it is good to know about it.
2.  Told how far your PC is off from the standard.  Under a second is good for many ham purposes (contesting, WSJT-X, more).
3.  Told what UTC time is and (obviously) your local time's offset from it. Again, should not be a surprise, but still. . .
Nice, single visual that tells your PC's time story.
K0RO
Re: New, improved accurate time and timezone info
« Reply #1 on: July 29, 2022, 12:11:34 PM »
Nice!  Thanks.
AA6YQ
« Reply #2 on: July 31, 2022, 11:26:43 AM »
Anyone know of a web service or web site that will report the UTC offset for a specified grid square or latitude and longitude anywhere in the world?
#1 DXCC Honor Roll, DXCC Challenge 3000
« Reply #3 on: August 01, 2022, 10:16:49 AM »
I don't think that is actually possible, at least not for grid squares.  Time zones are political decisions.
There's all kinds of strange anomalies.
1. Some jurisdictions are 30 minutes off.   That is, they decided to be so-and-so hours plus 30 minutes different from GMT.  Good luck discovering which (India happens to be one -- I just looked it up).  It's not always obvious why the choice was/is made.
2.  Some jurisdictions ignore their geographic location.  Iceland is on UTC when it should agree with Azores.
3.  "Daylight time" varies by the time of year and of course some jurisdictions don't participate.  Worse, the changeover times of these things have and probably will continue to vary over time.  So, you have to know the time of year and the political entity.
4.  I have no idea how one would properly set the time if one is in the open ocean with no land masses in the grid.  It probably is based on the captain's whim.
You are sitting on a piece of dirt somewhere.  Your four letter grid tells you not nearly enough.  But, if you know what political entity that piece of dirt belongs to, well, one way or another, you can easily look it up.
There may well be grids that straddle political boundaries, each with a different time zone.  Near me, some four letter grids straddle New Mexico and Arizona.  The time zone will vary based on which part of the grid is in one state versus another.
You just might be able to get pretty close with six letter grids.  But, political boundaries don't reliably follow grid lines no matter how fine it goes.  What error rate will you tolerate?  DXMaps makes a reasonable guess, but at the margins, it is likely to be wrong.
If you use actual lattitude and longitude of fine enough grain, then with the right kind of database, you might be able to make that work.
« Last Edit: August 01, 2022, 10:21:59 AM by WO7R »
« Reply #4 on: August 01, 2022, 10:36:20 AM »
If you have some programming skills, there are libraries and APIs that offer this capability. To get you started: https://stackoverflow.com/questions/16086962/how-to-get-a-time-zone-from-a-location-using-latitude-and-longitude-coordinates.
K4IBC
« Reply #5 on: August 01, 2022, 10:53:00 AM »
I believe Simon's World Map program has this feature built in.
https://www.g4eli.com/world-map
