Author Topic: Antenna mount hardware question  (Read 151 times)
KD0VE
« on: August 08, 2022, 12:37:27 PM »
I have a 90 degree angle bracket for mobile mount with a 3/8" hole for mounting an antenna.  The assembly that provides the 3/8" female connector for the antenna has a washer with a small step on it that keeps the non-conducting washer centered on the hole in the bracket.
Question (and maybe it doesn't matter):  does the non-conducting washer go under the bracket with the lip facing up into the bracket hole or over the top facing down?
thx to anyone offering advice.
WA3SKN
Re: Antenna mount hardware question
« Reply #1 on: August 08, 2022, 03:58:37 PM »
Depends on where you want any water seepage to go.  I will suggest applying a dab of GE Silicone II to the washer to help with the sealing.  I have tested it at RF frequencies up through 450 MHz and is a good insulator.  Clear, white, and black all test good. (some caulks use carbon to make black and are NOT good insulators!).
-Mike.
K7AAT
« Reply #2 on: August 08, 2022, 05:18:38 PM »
I believe WA3SKN   has misinterpreted the OP's description.   The 'washer' in question is apparently an RF insulator for the center pin circuit of the antenna mount.  I looked at a couple of mine,  which have the 'washer' in question on the bottom side ... where the nut threads on... but I am unsure if what I have is the same thing the OP was talking about.   A picture would have been helpful...
K7AAT
KD0VE
« Reply #3 on: August 08, 2022, 05:35:54 PM »
k7aat - you understood the question and answered.  thx.  underneath it is.
