Author Topic: SATPC32 MISSING FILE  (Read 108 times)
W6AOA
« on: August 26, 2022, 09:56:21 PM »
Keep getting this error msg.  cat works fine But, cant get the rotor to run. Yaesu G5500  with SAEBRT Trackbox.    Work great for couple years but stopped ??
tried screenshot..  not working
cant find server file C:\users\edschaff\appdata\roaming\satpc32\keplers\amateur.EXE
any advice  Ed W6AOA Pensacola, FL
Re: SATPC32 MISSING FILE
« Reply #1 on: August 27, 2022, 04:58:20 AM »
I would suggest reinstalling SATPC32 and be prepared to redo your settings afterward.
If you backup:
C:\Documents and Settings\(your username)\Application Data\SatPC32
before you reinstall and then restore that file afterward, you may be successful in restoring your previous settings.
« Last Edit: August 27, 2022, 05:09:43 AM by W9IQ »
W6AOA
« Reply #2 on: August 27, 2022, 04:21:15 PM »
Appreciate the assist Glenn
Backed-up settings,    uninstalled satpc32 12.9,   restored backed-up settings.  Still cant find  amateur.exe file  and now cant find  ORBSMANU.ELE when I try to search under the  SAEBRT Trackbox  in rotor setup.  Wonder if something is wrong with the settings I saved  then reinstalled ?  Any thoughts..  //Ed
« Reply #3 on: August 28, 2022, 03:35:35 AM »
The file ‘orbsmanu.ele’ and 'amateur.txt' (not .exe) are both Keplerian element files for the satellites. If these are missing, you may want to use the update Keplerian elements feature and select these files/websites to reload them.
W6AOA
« Reply #4 on: August 28, 2022, 04:49:03 PM »
Glenn,
The error msg clearly says AMATEUR.EXE right as the program first runs.
« Reply #5 on: August 29, 2022, 04:36:18 AM »
Ed,
I do not have SATPC32 installed at the moment as I am building a new station at my new QTH so I cannot check that file name for you. Hopefully someone else can jump in.
« Last Edit: August 29, 2022, 04:38:28 AM by W9IQ »
