Without the photo, it is difficult to tell.
But many manufacturers reuse the same parts on different
antennas. For example, a 48" whip may be a 5/8 wave
antenna for 2m, or designed for CB or other frequencies,
depending on the coil inside the base housing. The same
housing could be used with a 36" whip as a 2m half wave,
or for some other band.
So if there is no markings on the antenna itself, the only
way to know for sure is to put it on a mount and check the
SWR.
