Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: Here's how to build a real deal 6M tube amp.  (Read 1743 times)
Re: Here's how to build a real deal 6M tube amp.
« Reply #75 on: September 15, 2022, 06:58:59 AM »
« Reply #76 on: September 15, 2022, 08:06:20 AM »
No pics, Shane.
But the chassis is starting to take shape, per youtube.
You really should include some snazzy, color engraved graphics on the front panel.  I always did and the customers always seemed to appreciate it.
Guys running stuff this size generally don't want it getting out what they have.
  Yes ... well... (see discussions above)
Brian - K6BRN
Brian, you are mixing up apples + oranges again. Shane is talking abt another, different setup.  The U tube video is strictly the 6M amp.
« Reply #77 on: September 15, 2022, 08:28:34 AM »
Those contactors make my 300 amp - 3pole contactors look like rinky dink.
« Reply #78 on: September 15, 2022, 10:08:50 AM »
I only have a few contactors that size here at work.  Usually when we need to move that size current, we step it up.
I have 13.5kv distribution, 5kv distribution (which runs our MVR, a big Siemens 5kv motor) and 480 volt distribution.
Anyway, that's how the real big boys roll.  Those capacitors where about 1200 dollars I believe.  The transformer was wound by a guy in the same state and he got a HELL of a deal on it.
I've seen it loaded down to 8 amps, on the 10kv tap.  The tubes where old and tired by that point.  4CX15000J tubes.  We used those due to them having more emissions capability than A7 or other tubes.
Thank you for putting them online, James!
N0GV
« Reply #79 on: September 15, 2022, 12:33:14 PM »
It's a non issue with 10 kw pep out, (1kv peak)  even 20 kw pep out..(1414 V peak)
I am not questioning the efficacy of the antenna, just the application of the math. Your math above still needs some editing if you are concerned about the maximum vpeak voltage on the antenna.
At the 50 ohm feedpoint, with a 1:1 swr, nope.  At the tips of the DE,  assume it's gonna be sky high.
Math is nice -  but the math on wire size and dissipation are not gonna be at all nice - @ 50 MHz Cu wire has a resistance of about 0.9 Ohms/foot or about 100 Watts/foot. This is going to give problems. Feeding this with exactly what transmission line type? LDF 7-50 or perhaps something even stouter? RG-393 is beyond spec at 54 MHz and 10 kW... and that is NOT out in the environment....
Plus, just because it sort of highlights the issue: why would anyone want a dipole on 54 MHz? 1 kW into a 6 element Yagi-Uda will give you an effective main lobe power of 9 dBd in free space and 13-15 dBd over a decent ground. In real terms that is a lot better deal than a dipole at 10 kW as you can reduce environmental noise due to directionality....
That is reality. What you are describing is just ego.
Grover
« Reply #80 on: September 16, 2022, 08:11:26 AM »
Grover
Grover, do you think we are all as stupid as a brick ??   The basic formulae is just for average current..... and RMS / peak Voltage into a 50 ohm matched load.
It's then up to the END USER to use APPRPORIATE  rated connectors, main coax, flexible coax for rotor loops, line sections,  mode, duty cycle, CM chokes, relays, and everything / anything else used downstream, including ants, corona balls, tubing material suitable for the current / voltage...on 6M.
LDF 5-50 rated for  10.91 kw CCS  @   50 mhz.
LDF 6-50 rated for  17.42 kw CCS  @   50 mhz.
LDF 7-50 rated for  23.63 kw CCS  @   50 mhz.
So no, heliax bigger than LDF 7-50 is  NOT required.  Try learning how to read a spec.
SFT-600  teflon, flexible coax (teflon version of LMR-600UF) is  rated for  13.1 kw CCS  @  50 mhz.
This is what is typ used for rotor loops.   SFT-600 is also used for shorted  1/4 wave stubs.  A shorted 1/4 wave stub will be installed inside the RF deck, across the vac load cap, to supplement the even order harmonic suppression.   That's on top of the existing  C-L-C-L-C  (L-PI) output network.  It will also be used to DC ground all the tank components, instead of the typ safety choke used across a load cap.
IF 2 x yagi's used, the feedline to each yagi only has to handle 1/2 of the applied power.  If 4 x yagi's used, like 4 x 11 ele long boom yagi's on a H frame,  each feedline to each yagi only has to handle 1/4 of applied power.
Ditto with 3 x yagis...each handles 1/3 of applied power.
For driving 2-3-4  yagi's in phase, various methods of splitting can be employed.    For HF, monoband  arrays, simple LC networks are used... shunt C and series L.  50 ohms in..and   25/16.66 / 12.5 ohms output..... that then feeds 2/3/4 output connectors.  Then equal lengths of coax to each yagi's feedpoint.
What I have just described here IS the reality.  Everything has to be carefully designed, sized, constructed and configured for this application / configuration.   We don't just... 'guess'  or use  ..'trial + error' methods.
« Reply #81 on: September 16, 2022, 12:16:31 PM »
Just watched the video.  See a couple things I have questions about.  First is the distance from the HV connectors to the bottom place and bottom cover,  it just looks a bit close.  And, putting the banana jacks next to the 7KV supply line.  Again, it seems kind of close.  7KV will jump a pretty good distance.
There is NO HV connector in that video. All the connectors, jacks, fuses etc, are below the chassis.   The HV will be installed later....on top side of chassis.
W4CDO
« Reply #82 on: October 27, 2022, 07:02:59 PM »
Thought you guys were limited to 2200 watts.
It's not for me.  I just designed it...that and the HF versions as well.   That's what the client wants.  That's what they get.
So, will your client be operating FT8?
« Reply #83 on: October 28, 2022, 09:13:19 AM »
No clue.
AA7IS
« Reply #84 on: November 01, 2022, 12:05:09 PM »
Most boring thread on EQSL, congrats lol.
KM4AH
« Reply #85 on: November 01, 2022, 03:03:51 PM »
Are you familiar with the term "spin the knob"?
« Reply #86 on: November 02, 2022, 08:48:24 AM »
Dumbest comment on EHAM.
This isn't EQSL.
« Reply #87 on: November 02, 2022, 09:53:20 AM »
You have a BSEE degree  from the U of W.  You tell us how to build a 10 kw CCS  6M Linear amp,  tube or LDMOS.  I'm all ears.  Here's a subtle hint.  You won't find it in any engineering books.
« Reply #88 on: November 02, 2022, 09:55:02 AM »
He can't differentiate between eham and eqsl.
I doubt he can regularly find the on/off switch on a power supply.
Pages: 1 2 3 4 5 [6]   Go Up
