Author Topic: Windows 11 and Xiegu G90S  (Read 157 times)
BG8VZ
« on: September 06, 2022, 11:37:54 PM »
    Actually ,it's not so hard for me to connect G90S with Windows7/10. It's also convenient to use HRD/N1MM/JTDX with G90S on Windows7/10. I used a data box to connect it with the computer,It works well .Maybe a software called 'omnirig' is needed .But it's not so easy to connect G90S with Windows 11 .The driver of data box is unable to install on Win11 and Omnirig is also unable to install on Win11 ,If I want to use HRD or something else ,G90S was always on transmitting without power .I guess that maybe something wrong on the Win11 system or the driver of data box is out of date .
     If  you know how to connect the G90s with Win11 ,please tell me the process .Thanks a lot .
     By the way ,hope everyone is healthy and in good condition .Good luck !
BG8VZ
Re: Windows 11 and Xiegu G90S
« Reply #1 on: September 07, 2022, 01:53:15 AM »
   I asked some programmer for help .Then I got the answer .I have to set the system to my time and zone ,in the management .Then the "omnirig" and the driver of data box can be install .Everything goes well .
     Thanks for your reading .Good luck to everyone !
