Author Topic: FT-990 side tone?  (Read 221 times)
W0BKR
FT-990 side tone?
« on: September 08, 2022, 06:39:21 PM »
Turning radio on going to cw mode, the radio has a constant sidetone ( I assume that is what it is.  How to disable it not seeing it in the manual.
W3FLH
Re: FT-990 side tone?
« Reply #1 on: September 08, 2022, 07:17:06 PM »
Check your MOD MOX button - it will produce a constant carrier.  Or else make sure your key and/or mic aren’t engaged.
Tony W3FLH
« Last Edit: September 08, 2022, 07:19:46 PM by W3FLH »
W0BKR
« Reply #2 on: September 09, 2022, 06:31:23 AM »
Need some help  When I place the radio in cw mode, I get the side tone immediately  When you depress the VOX to Semi BK In, radio goes into transmit.  I have no key plugged in the front or rear of the radio.
Any ideas?  Not familiar with this radio but would think you would have to have a keep plugged in to get that situation
« Reply #3 on: September 09, 2022, 06:53:11 AM »
I am not certain about the 990 but many radios will effectively short the CW key connection (simulates a key down condition) when there is no plug inserted in the CW jack. This is for the convenience of tuning, etc.
W3FLH
« Reply #4 on: September 09, 2022, 08:21:35 AM »
OK, if it's happening in VOX, check your VOX settings on the top panel (under the flip-top) - the VOX GAIN or ANTI TRIP may be too high, and it's tripping the TX even though you have no mic or key in place.
Tony W3FLH
W0BKR
« Reply #5 on: September 09, 2022, 11:27:06 AM »
Suspect a keying line short, and cannot key the radio with a key only get contact tone using vox oof semi break in.  Nice the seller did not mention that issue..off to a repair shop.
W3FLH
« Reply #6 on: September 09, 2022, 11:59:26 AM »
Ouch - sorry it wasn't a simple fix.  Good luck with it, they're great radios when in working order.
Tony W3FLH
W0BKR
« Reply #7 on: September 09, 2022, 03:10:28 PM »
Guy wasn't honest about and now I am stuck with a repair to pay for...
W0BKR
« Reply #8 on: September 09, 2022, 07:04:38 PM »
Just frustrates me to run into these crooked scammers on QRZ.  When confronted about the anomaly with this radio he tells me to read the book.  What crap.  I know how to use a radio and how it is suppose to work.  Chalk it up to another lousy scammer selling some crap on a swap board he picked up from a hamfest.
W0BKR
« Reply #9 on: September 28, 2022, 03:54:15 PM »
Well, WS1C passed off a defective damaged radio and claimed it worked fine.  Here is the write up:
Problem reported: Constant CW key.
NOTE: High voltage entered key port and damaged various components on switch
"SW-A-unit" unit including CW CPU and protection components. CW CPU is no
longer available. Customer would need to locate a switch "SW-A-unit" unit to
have keyer fully operational.
Work performed:
1. Performed CW internal keyer bypass mod. (Required 1 resistor and 1
capacitor).
2. Calibrated master reference.
3. Calibrated S-meter (50uV=S9).
4. Replaced defective memory battery.
5. RX tested OK, <.2uV @ 12dB SNR.
6. TX output tested OK, >100 Watts.
7. Antenna auto-tuner tested OK, >3:1 matching.
8. Front and rear CW ports tested OK, can use straight key or external iambic
keyer.
No more internal keyer (I don't care but I bet someone will if I wanted to sell it later on).
$200 with shipping back to me.
