Author Topic: FT8, Can not enter 70cm FreqWanting to run FT8  (Read 183 times)
KS2K
« on: September 10, 2022, 09:06:47 AM »
Wanting to run FT8 on 70cm, I go to the pull down box to click on frequency.  But it only goes up to 2 meters.  I can manually enter
the frequency in the pull down box, but then it shows the frequency in
red which show out of frequency.  How do I enter a 70cm Frequency, and what is the most used 70cm FT8 frequency
KS2K
WA9AFM
Re: FT8, Can not enter 70cm FreqWanting to run FT8
« Reply #1 on: September 10, 2022, 10:51:08 AM »
Using WSJT-X?
If so, go to 'Settings', select 'Frequencies' tab, cursor down to the current 70cm frequencies, RIGHT click on any of the UHF lines, when the menu pops up select 'Insert', for IARU Region select 'All', mode 'FT8', for frequency '432.174', to exit, click 'OK'.
KS2K
« Reply #2 on: September 10, 2022, 11:06:48 AM »
WA9AFM;
Got it. Easy 30 sec fix.  Thank You so much for your help
KS2K
WA9AFM
« Reply #3 on: September 11, 2022, 05:49:37 AM »
Glad to help.  See you on the waterfall.
