Author Topic: No Reeption V/Uhf  (Read 148 times)
KD9DOG
No Reeption V/Uhf
« on: September 19, 2022, 06:35:29 PM »
I have several handhelds and all are doing the same thing they receive no signal, the repeater in Polk County, WI 54006 is at 147.195 +.600 and tone of 110.9 my radios are Yaesu FT-4X and Baofeng UV5R and UV5XP, and GT-5R.
Freq is set at 147.195  +.600 my tone receive and transmit are 110.9 SQLC is set at 1, I have had the radios on all day and have heard not a peep, I do know that these radios will not wake the repeater due to the distance of about 20 miles but I would think they woud receive any suggestions?
Jim KD9DOG
WA9AFM
Re: No Reeption V/Uhf
« Reply #1 on: September 19, 2022, 08:10:31 PM »
Although you didn't mention it, presume you are listening on your HT's with 'rubber duck' antennas.  Receiving a repeater 20 miles away on a 'duck' is a bit of a stretch.
Also, make sure you don't have 'digital code squelch' (DCS) invoked in your HT's.  If the repeater/s you are monitoring are not transmitting a DCS tone, you will hear nothing.
A third thing, repeater activity nationwide has dropped off.  I might be the repeater/s in question are just not being used.
Tom, WA9AFM
KD9DOG
« Reply #2 on: September 19, 2022, 09:31:50 PM »
Thank you I will look into it.
Jim KD9DOG
W6SWO
« Reply #3 on: September 19, 2022, 10:22:01 PM »
Also make sure you haven’t enabled TSQL (tone squelch).  You want just “encode” set to the proper tone to key the repeater.
Also, some radios have a lockout or transmit disable function that you might have inadvertently set.
« Last Edit: September 19, 2022, 10:24:55 PM by W6SWO »
