Author Topic: Anytone 878: Can't select channel  (Read 147 times)
VE7EPX
« on: September 20, 2022, 02:46:15 PM »
I have had my new AT-878 II Plus for about a week now and have used the CPS app to set up my zones, lists and channels. The app and the upload to the rig have worked flawlessly and I have successfully tested the radio using the primary channel.
What I am unable to figure out though, is how to manually select an individual channel that is in my list. Like other handhelds I've owned, I assume that the Channel Switch Knob is used somehow to scroll through my list. That's not happening and I haven't figured out how to make it happen. Is anyone familiar with how to enable the channel-select function? Thanks.
G4AON
Re: Anytone 878: Can't select channel
« Reply #1 on: September 20, 2022, 03:12:43 PM »
You need to put each channel into an appropriate zone. You then select a zone with the up/down rocker, then rotate the top control to select the channel.
For example I have zones for my hotspot, marine VHF (RX only), UHF simplex, VHF simplex, analogue repeaters and the local DMR repeater.
Hope that helps.
73 Dave
VE7EPX
« Reply #2 on: September 20, 2022, 03:54:12 PM »
Dave, thank you very much for your reply. After about 4 hours of frustration trying different configurations, it took about 2 minute to follow your instructions and get the channel knob to work.
Much appreciation and best regards,
Dave L
VE7EPX
