I believe that Tom (W8JI) is being misquoted on the matter of replacing the FOUR 811a's in an AL-811H amplifier with THREE 572B's.
I got the following verbiage from the following URL: https://www.w8ji.com/al811h_schematic.htm
Quote:
"It is perfectly acceptable to replace the 811 tubes with three or four 572B tubes in the AL811 or AL811H respectively to increase duty cycle and tube reliability."
Note the words "in the AL811 or AL811H respectively". In plain, Americanized English this means "3 811a's replaced with 3 572b's" in the AL811 amp, and "4 811a's replaced with 4 572b's" in the AL811H amp.
If you take an amplifier whose output pi-network is matched to transform the parallel impedance of four tubes and match that to a 50 Ohm output load while having only 3 tubes populated, you're going to have problems, as your design impedances won't match the design's criteria. Ever try to drive a 4 cylinder car with only three spark plugs firing? It doesn't work so well.
It's just another design criterion that 572b's are plug-in compatible with 811a's, albeit with greater maximum plate Voltage and RF power output, if the DC power supply of the amp is capable of supporting this. The power supplies of the AL811 and AL811H are NOT capable of providing this higher power level.
The only thing you get by substituting 572b's for 811a's is more ruggedness for longer tube life...nothing else. But the replacement has to be "3 tubes for 3 tubes" or "4 tubes for 4 tubes" depending on your 3 or 4 socketed AL811 "series" amp.
Sorry.....but no free lunch.
Good catch on the 811 vs 811H.
However, 3 x 811A's could easily be replaced with just 2 x 572B's.
And 4 x 811A's could easily be replaced with just 3 x 572B's.
811A rated for 175 ma
572B rated for 275 ma.
The number of tubes installed has nothing to do with the tank circuit. It's loaded B+ and plate current, that's it.
Run the same OEM plate current with either 2 or 3 x 572B's in the AL811 OR run the same OEM plate current with either 3 or 4 x 572B's in the AL-811H.... and plate load Z stays the same, and PI net stays the same.
However, after saying that, if only 2 x 572B's were stuffed into the 3 tube amplifier, the fil V would probably rise a bit, cuz of the lower fil current. The tuned input would be outa whack, with one less tube installed, since the input Z would increase a bunch. And ditto with stuffing 3 x 572B's into the 4 tube amplifier.
Tom cautions that some of the 811 amps have the wrong fan installed, that only blows 30% as much air as what was originally in there. Dunno if all new production amps have the wrong fan or not. With the wrong fan in there, you will end up having a bad day, regardless of tube choice.
