Tom is literally swamped with repairs to Ameritron solid state amps.
https://www.ctrengineeringinc.com/welcome-to-ctr-engineering-inc/ameritron-and-other-amplifier-repair-service/
After Tom left Ameritron in 2019, whatever quality left, went out the window. On his Ameritron FB group, he sez the quality of the Ameritron SS amps is beyond piss poor. Primary failures are devices not attached properly to the mating heatsink. He sez he spends 8 hrs repairing just one SS amp, loses money on every one of em, and repairs include wetsanding everything to a mirror finish, replacing devices, and using the correct type, and amount of heatsink goop. Tom sez some of the units that came in would handle 300w ccs, some 400w, some 500w, it's all over the map. He also showed pix of the ameritron..'repair' jobs..which was done badly. Owners gave up, then sent the 'repaired' unit to Tom, for the correct repair.
Other issues were ameritrons changing the sequence of the LP filters. The highest freqs should be the furthest away from the main input, same as my AS remote switch box. Otherwise, you end up with a stub effect, due to the myriad of relays used to switch the myriad of LP filters. You can't avoid the stub effect, so the lowest freqs go closest to the input. I know one fellow who's AL-600 blew up in < 1 min, brand new, ditto with the replacement. 3rd unit was fine. The 1st 2 x units, the devices were not even touching the heatsinks, wtf?
One fellow on the amp forum, had a contract with one of the HRO's (this was years ago). His job was to unbox, and test each ameritron tube amp, before HRO shipped it to the customer. He ended up taking them all apart BEFORE plugging them in. Typ issues were stuff not soldered, tank coils leaning over, and ready to short out, HV lytics installed backwards, eq resistors across hv caps missing, or not soldered, or gone open.. you name it. 'Simpler' to find and fix all those issues 1st...THEN plug it in and test it. Otherwise if you just test it 1st, stuff blows up.
There is no way in hell their amplifiers are tested before they leave the factory, not a chance. No QC stickers on em. For all the hassle, and shipping all over the map, repairing, shipping back etc, it woulda been cheaper to just test each unit before it left the factory.
Below is from Tom's site.
"Ameritron (and other) Amplifier Repair Service.
Until further notice, we have decided to halt all intake of amateur amplifiers. A large part of this decision centers around construction inconsistencies in Ameritron amplifiers, the time it takes to find random incorrect parts, and the time and risk involved in correcting component and workmanship errors.)
