When we started traveling in our travel trailer again, about 9 years ago, I bought an Alpha Antennas 80-6 Meter vertical. (The PVC version of the FMJ.) It is quick to put up, and I thought would be less conspicuous. I got WAS, and 89 DXCC with it during the last cycle.
A few years ago I built a version of the MFJ Octopus, after buying one and seeing how bad it was put together. I use 4 pairs of Hamsticks, (40, 20, 17, & 10) the advantage over a buddipole (Which I 1st looked at.) was that you do not have to retune it everytime for a band change. (If I had to do it again, I would just buy a Chameleon Spyder.)
This New England camping season, I added the ARRL EFHW kit, with a 43' fiberglass pole in an inverted "L" configuration. Surprisingly it worked very well.
I use an FT-450D, Xiegu G90 & X6100, with a MFJ manual tuner, when needed.
Gary W1MOW
