Pages: 1 2 3 [4] 5   Go Down
Author Topic: Alpha 9500  (Read 1510 times)
N2SR
Re: Alpha 9500
« Reply #45 on: October 13, 2022, 09:38:23 AM »
...and the Acom 2000A actually states "Constant carrier modes 1500W output - NO TIME LIMIT with auxiliary cooling fan". Sounds like a brick-on-key feature to me.
I added the PS fan myself.  Not for RTTY, but just to keep everything cooler.  I have noticed a slight drop in tube exhaust temperatures.
I'm a big fan (pun intended) of adding more cooling capability to any amplifier, if it doesn't add too much more noise in the shack. I purchased a variable speed, two muffin fan device from Amazon, and placed it on the cabinet top vents of my Acom 1200s to assist the exhaust flow of heat over the PA module. It seems to lessen the normal increase on the temperature indicator over just the internal fans.
This is just a standard muffin fan, but I wired it so that it only gets ~ 100-Vac, and it blows air into the PS compartment.  It's totally silent.  Hardest part was figuring out how to incorporate a filter.  It's not super pretty, but I used 4 1" rubber washers.  The washers keep the filter from falling off when the amp is off and the fan sucks the filter against the fan guard when the amp is on.  So it's easy to remove/replace when necessary.
Elect a clown.  Expect a circus.
Re: Alpha 9500
« Reply #46 on: October 13, 2022, 01:30:18 PM »
Anyone complaining of blower or fan noise is more than invited to come listen to my Harris RF103.
Blower, chassis fan, etc.  3Kw Choke input supply (so some healthy bleeders).  What's not to love.  The sound of a 747 at the end of a runway at full throttle with my ear to the output of the turbine?
I've not found anything near it for fan noise, sans my Henry 8k chassis....  And that's saying something.  Then again, that's another one with fans and blower.
AF6D
    • AF6D
Re: Alpha 9500
« Reply #47 on: October 13, 2022, 04:51:42 PM »
Bob,
If you haven’t already, take a look at OM Power 2501A. Current, modern, fully supported amplifier from a company that is actually in business. Uses a single FU-728 that is readily available for under $400. Built-in remote access server if you are interested in operating your station remotely. The latest firmware adds true auto tune (vs memorized settings).
Rudy N2WQ
Thank you for the suggestion Rudy. I took a look at it and it doesn't go to 6 m. I've been looking at the Alpha 9500 as a highly rated amp, but it also doesn't do 6 m. That puts the KPA 1500 out in front. I'm not big on contesting but the last contest I worked we came in third place and I worked 6 m the entire time with only 100w and a 3-el beam. It was a good day that day. Armchair copy to the Midwest and East coast. I love 6 m. I will be honest that I thought the Alpha did 6 m, so... much to my chagrin, I was caught off footed by this one.
I generally don't like all in one units. That's why in my station I currently run a Yaesu ft 8900 as well as a Yaesu ft 847. And then of course my Yaesu ft 2000 that I wish I could tie a chain and an anchor to and throw it overboard. Early in it's warranty I detected receive relay chatter and it went back for a replacement. It has never had the receive it should have had and the speech compressor is terrible. On the other hand, the Ft 847 overcomes both of these and it's 25-30 years old.
The point I'm making is that I generally try to divide things up and the fact that an amplifier does not have 6 m does not necessarily mean that's a no. But there doesn't seem to be a good and current 6 meter all-mode radio. I can be guilty of going off topic so I will refrain from doing that much further. Hopefully this narrows down my search but again if I need to separate 6 m as a separate operating unit I can go that direction. When you put all in one unit and that unit goes out you're pretty much in trouble during an emergency.
AF6D
    • AF6D
Re: Alpha 9500
« Reply #48 on: October 13, 2022, 05:10:25 PM »
Bob,
Rudy N2WQ
That would be another good choice, as well as an Acom 2000A, if you’re still considering a legal limit, auto-tune tube amp. Alpha is still wallowing in the mud…who knows when/if they’ll be up, running, and delivering amps.
The only negative I’ve heard/read about OM Power amps is their loud blowers. Maybe they’ve done something to remedy that with the xx01 series.
The Acom meets my frequency specifications and P-Po. I'm not sure the remote interface is the way I'd like to go. My station is being designed to be almost entirely rack mount. That's mainly just to keep things securely on the worktop and since I currently reside in California all together in an earthquake. But the Acom would be a strong contender.
N2WQ
Re: Alpha 9500
« Reply #49 on: October 13, 2022, 05:31:04 PM »
Bob,
Rudy N2WQ
Acom 2000 does not do 6m. OM Power 2000+ auto does. I have one and love it.
Enjoy your shipping quest. It’s fun.
Rudy N2WQ
AF6D
    • AF6D
Re: Alpha 9500
« Reply #50 on: October 14, 2022, 12:11:07 AM »
Bob,
Rudy N2WQ
Rudy N2WQ
Thank you again rudy. I've gone to their website and they don't have a 2000+ listed any longer. Perhaps one is available on the used Market. It looks like a nice amp and om has a good reputation. That's really all I ask for is a manufacturer that stands behind their product and that the product performs as specified or better. As I understand it the OM's have louder exhaust. It's My Hope actually to put a shroud on it with an additional exhaust fan to pull it out and away from the wall. I believe I've read that others have changed the fan all together and it did not seem to vent as well as evidenced by higher internal temperatures. Are you familiar with this and have you experienced the same issue by changing the fan? I believe it was referred to as a PS.
N2SR
Re: Alpha 9500
« Reply #51 on: October 14, 2022, 02:33:57 AM »
I believe Array Solutions is the US dealer for OM Power.  Give Jay a call and see if he has any 2000+ amps in stock.
Also, check your email.
Tom, N2SR
N2WQ
Re: Alpha 9500
« Reply #52 on: October 14, 2022, 04:36:12 AM »
Bob,
Rudy N2WQ
Rudy N2WQ
Here's the description of the amp https://www.om-power.com/products/om2000aplus
You can order it directly here and take advantage of the weak Euro https://shop.om-power.com/amp-product-276
With respect to fan noise, it's relative, based on your operating style. I am a contester and always operate with headphones so the noise is irrelevant. The fan has different settings and I set it to always on, albeit it at a lower speed, to keep the amp cool at all times. I am an avid RTTY operator and my amps do 48 hour RTTY contests.
In addition, given the excellent remote capabilities of OM Power amps, you can have the amp far away from your operating position. In my case, I envision moving all amps to the base of the tower, 200' away.
Rudy N2WQ
KA4WJA
Re: Alpha 9500
« Reply #53 on: October 14, 2022, 08:28:35 AM »
EDIT:  My original response here exceeded the max character limit, so I need to edit out some....so..
Bob,
1)  First off, please accept my sincerest and heartfelt apologies....especially for addressing you as "Rob"....it was an erroneous assumption on my part as my older brother "Robert" is called "Rob" (and, you didn't sign any of your posts, so I made a casual mistake and addressed you as Rob rather than Bob), so in addition to my other errors this one is simply a mistake of mine due to a casual assumption.
I am sorry about this, really I am!
Even though I'm a easy-going/casual guy (and do write and talk about ham radio in a very casual way, as opposed to professional/career situations), I now realize that some folks take this casualness as an affront....so, please accept my apology here, I meant no offense and I am sorry that my casual erroneous use of Rob offend you!  :(
2)  Secondly, please know I am truly sorry for hurting your feelings, and for your feeling condescended to, or insulted in any way!   This was 100% not my intention, ever!  :(
{heck Bob, you were asking about an "Alpha", I was thrilled to help!  (anytime I get to rave about Alpha, is a good time for me!)
And, I am still attempting to help!
So, I do hope you will see that my intentions were actually those of being a "nice guy" and fellow long-time ham, with thoughts of promoting "good will", and attempt to help my fellow hams....
And, I get to ramble-on about (and tout?) Alpha's....that is a pleasure....
So, I hope when you read this here, and what I highlight below, you'll see this is a simple misunderstanding my friend....and, I am truly sorry about that!}
3)  Next, allow me to further apologize, this time in detail....(I did attempt to apologize to you earlier, and it seems that my statements of regret, continued info / answers to your query, and further offers of any assistance have gone unnoticed....so, allow me to move forward in detail, so there is no further misunderstanding...)
From what you now write it seems to me (in my opinion), the majority of the problem here was my abrupt writing style / and sort-of "short-handing" of thoughts, where I made assumptions that you were understanding my train-of-thought, and whereby you misinterpreted what I was writing.  :(
Bob, PLEASE read again what I wrote Wednesday in explanation...I realize I was vague, but I never for a second was attempting to "talk down" to you, nor to ever be condescending....and, it is unfortunate that I failed to include a few descriptive / directive words in a few paragraphs of mine, in my original posting here / my original attempt to answer your query, and I feel if I had simply included just a few short words in those sentences, you would've clearly seen that, quite opposite of what you inferred, that I was stating that since all those questions have already been discussed over-and-over again, there was no need for me to bother you with them, as you were evidently looking for more detailed info/comparisons, and what I (we?) needed to give you more specific info (on the '9500 and other choices) and some detailed recommendations, was more info from you.
While perhaps in an inept way, I was attempting to draw more info / details from you, so that I actually could offer you some more specific recommendations.  :(
And, I failed to write that properly, for that I accept responsibility and ask you to accept my apologies.
If we look at what I wrote, and simply [added the words that were in my head but not on the screen], I feel this whole episode of you inferring you were condescended to, could have been avoided.
The way I'm now interpreting your question(s) [please correct me, if I'm wrong] is less about the Alpha 9500, and more like many of the questions here regarding amp selection....[we just need to get more info from you, in order to give you a more critical look at the '9500 and better answer your queries]
These are the typical:
"what amp should I buy?" ....
"Solid-State or Vacuum-Tube?" ....
"how good IMD do I need?" ....
"do I need 1500 watts out?" ....
"do I need 100% duty-cycle, no time-limit, 'brick-on-the-key'?" ....
"if I desire a 'tube amp', which tubes should I avoid / which ones to look for?" ....
"if I desire a SS Amp, which devices should I avoid / which ones to look for?" ....
"are there 'no-time-limit' SS Amps?" ....
"what is the 'best' amp?" ....
etc etc.
etc....
And, to be blunt, all of these questions have been asked, answered, and beaten-to-death...over-and-over again....many times here....so, [there is] no need [for me] to go through all of this again.
I feel strongly that if I had just included these few words, above in red and in brackets, that I was thinking but didn't type, then we would not be here today discussing this, but rather having fun with ham radio and helping our fellow hams.  :(
And, here again, I apologize for this, it is my error for taking short-cuts...I am sorry that I failed to write better, and that I failed to convey my sincere interest in actually helping you, and most importantly I am sorry that I failed to be even more blunt and direct..
(which could've been as easy as asking "AF6D, please let me know exactly what you want / need in regards to a new amp, and what about the Alpha 9500 looks "good" to you and what about it looks "bad" to, and I'll try to help...73,   John,  KA4WJA")
I suspect if I had been "less me" / less verbose, and just written that, we'd not be spending our afternoon on these ancillary, personal matters, but rather actually helping our fellow hams!  :)
And, again, I am truly sorry about all of this!
Please accept my apology, and let's move forward?  Yes?   ('cuz, I really don't want either one of us to feel like a horse's patoot...hi hi)
Now Bob, if all of my honest and sincere apologies above, are not acceptable to you, and/or you still feel "talked down to", then I will leave you to proceed without any further assistance, clarifications, recommendations, etc. from me, and I wish you a good afternoon....BUT...
But, if you can accept my apologies and my errors, and move forward....I am still happy to help in any way I can....and, I'm including some additional info for you, below...
And, if you could answer these questions:
"AF6D, please let me know exactly what you want / need / desire in regards to a new amp, and what about the Alpha 9500 looks "good" to you and what about it looks "bad" to, and I'll try to help...73,   John,  KA4WJA" ...
I will attempt to not be casual....and I'm fairly sure all of us here would be of more / better help?
John,  KA4WJA
Rob, Bob,
You're welcome!
The way I'm now interpreting your question(s) is less about the Alpha 9500, and more like many of the questions here regarding amp selection....
etc etc.
etc....
<snip>
2)  Just to get you started, here are some very brief generalities:
a)  I compared many modern amateur HF amps...have a look.
https://www.eham.net/community/smf/index.php/topic,100600.msg809639.html#msg809639
b)  In general, SS amps cost more $$$ per watt....as well as usually needing a tuner (either built-in or external), unless all antennas present a VSWR of 1.5:1 or less.
c)  General rules-of-thumb of modern Solid-State amateur HF amps:
----  Most SS amps are "instant-on", and require no "tuning" per se....just band-switching....(many can be controlled by the transceiver, providing totally smooth / seamless operations.....and many can also be run remotely, via IP controls)
----  In general, amateur SS amps are not "no-time-limit" / "brick-on-the-key" at 1500 watts / legal-limit out, but rather use some weird / quasi-deceptive marketing (such as "no-mode-limit", or "reduced output after xx seconds", etc.) to imply high-duty-cycle operations.  (in actual fact, they are all limited by their cooling capacity / ability to cool the device itself....and, most have temp sensors that fault-out the amp into "standby", once temps rise to their limits....some have "timers" that only allow constant carrier operations for 7 - 8 seconds, before faulting to low-power or standby....
---- Ironically, most modern SS ham amps will run "continuous carrier" at approx 50% - 70% of their rated/advertised outputs....and, this point (50% - 70% of advertised output) is also usually close to the amp's 1-db compression, which generally means that you can figure a linear output at approx the same power, or a bit lower....{yes, if comparing to legal-limit tube amps, this means that most SS ham amps that are advertised as "1500 watt amps" are really 750 to 900 watt amps....and those that are advertised as "1500+ watts" / "2000 watt max", etc. are actually 1000 - 1200 - 1300 watt amps... :( }
----  Solid-State amps have worse IMD products than tube amps, many times significantly worse.  (although, when looking at the better SS Amps, it is usually the transceiver's IMD that is worse)
----   Most modern amateur Solid-State amps (not their internal device specs, but the whole amp itself) have a 1-db compression point at approx 60% to 75% of their "advertised output" ---- yes, meaning that at their "advertised output", they are not running linearly!  :(
----   The only way to use most modern SS HF ham amps with good linearly, is to run them significantly below their rated/advertised outputs.  (although, still not as good as most tube amps)
----  All SS amps will need to be run into a matched load, with VSWR's of 2:1 or less....most will need VSWR's of 1.5:1 or less to produce full output, and anywhere close to clean linearity!
----  Due to the need to cool the device, most SS amps have rather loud (and annoying?) cooling fans.
d)  General rules-of-thumb of modern vacuum-tube amateur amps:
---- In general, tube amps are much cleaner / much more linear than SS amps.
---- In general, only the bigger tube amps (like Alpha) will be 100% duty-cycle, no-time-limit, "brick-on-the-key" at 1500 watts / legal-limit output.
---- In general, tube amps are much more forgiving than solid-state amps in regards to "oppss" moments!
---- In general, most tube amps will run their rated power into VSWR's of 3:1, and many will do into much higher VSWR's.....most will run VSWR's up-to or beyond 5:1 at reduced power, with good linearity and no damage.
----   Some tube amps have almost silent cooling (legacy Alpha's)....but, unfortunately, some are loud, like a jet engine (OM Power).
----  Eimac 8877 / 3CX1500a7 tubes are very linear, very rugged, and will last decades and decades....but if purchased new from Eimac/Richardson are wicked expensive (~ $1800)!  NOS (New Old Stock) Eimac 8877's are available for ~ $400 - $500 each, and will also last decades (in storage or in an amateur amp)...{fyi, I have four Eimac 8877's that are over 40 years old, and still running full-output, and wicked-clean and linear!  And, many, many other hams have the same experiences! }
---- Other ceramic-metal power-grid tubes (transmitting tubes), such as the 4CX1500b, 3CX3000, 8874's, etc. are also still made by Eimac, and some are decently priced and some are pricey!
----  8877/3CX1500a7 tubes made in China (with various "brand names" like Penta, Machet, etc.) are good, and many folks use them without issue for years....although some report slightly worse linearity and longevity, they sell for ~ $800 - $900, new, with warranty....
----  3-500z tubes (and all glass transmitting tubes these days, and for > 10 years) are all made in China....the "good ones" are sold in the US by RF Parts, for ~ $300 - $350 each, and come with warranty and should last you years of service....
----  other glass transmitting tubes, like the 811a, 572b, etc. are only made-in-China, and have sporadic reliability.....i.e. ya' pays ya' money ---- and ya' takes ya' chances!
As for what amp to buy?
That's a great question....may I suggest you read thru the pages and pages of discussions here....AND make sure you are making a decision for you and for your application / desire, not mine, not others..
As example, if all you want to do is rag-chew on SSB, then you do not need a "brick-on-the-key" amp, as well as not needing "instant-on", or "no-tuning", etc....and, if you're good at repair / circuitry, etc, then you do not need a "new" amp...however, if you're into contesting, or RTTY, etc., then a heavy-duty amp is called for, such as a "brick-on-the-key" Alpha...and, if you need instant-on and/or instant band-change with no "tune-up", then either an Alpha 9500 or a good solid-state amp (Expert 2K, or Flex Power Genius, or Elecraft 1500), might be good choices for you....
But, again, it should be your choice, based on your application / your desire, not mine or others....(the above are just random examples)
I do hope this helps.   (please read the many threads here discussing these matters, and assess them with your own application/desire in mind)
John,  KA4WJA
Rob, Bob,
1)  Okay, you now let us know a tiny bit more:
I have an assortment of amplifiers and I want better.
While we still don't know what your use/application is, nor what assortment you have, nor what "better" means to you (more reliable, easier to tune, cleaner IMD, more power, 100% duty-cycle at full output, etc. etc. etc.?  we have no clue)
So....with that general "question"....here you go:
a)  In my opinion, the Alpha 77Dx is the finest desktop amateur HF amp ever made....
You can find a clean one, in good shape, for ~ $3000 - $4000, with a good 8877 in it.
The amp will last a lifetime!
The 8877 will last you many decades!  :)
It (and the 77Sx) is the cleanest (IMD) desktop amateur HF amp made.
Wicked reliable, extremely easy/quick tuning, etc. etc....
b)  In my opinion, the Henry 3KD-Premier 8877 is tied for second-place (along with my personal fav the Alpha 77Sx...but I won't bother to detail that again)
Henry didn't make that many (but you can find some other Henry 3K's that have been modified/upgraded to a 3KD-Premeir 8877, as well)....I haven't seen any for sale in a while, but have a look around, you never know.
c)  In my opinion, the Henry 8K Ultra (big, heavy, 2-piece unit....with desktop control box and remote amp console) is probably the finest amateur HF amp made....but it is not a desktop amp, and it ain't for the squeamish!  :)
I've seen them sell for ~ $10k - $12k....but, I personally don't think I'd pay more than $6k - $8k
It, and its 3CX3000 tube, will last you for decades!
And, it's damn clean in IMD department as well!  :)
There you go...
In my opinion, those are the top 4 choices, in regards to "wanting better".
(if we had more info about what you interpret as "better", and what your application / use is, well then we could all probably give you more specific answers and most importantly the reasons that we recommend or not recommend a particular amp for you / your application)
If none of those appeal to you, or if none of those fit your application, or if none of those fit your definition of "better", then have another look at the Alpha 9500, and give Mike D. a call or email, at Alpha!
That would be my recommendation.
2)  As for me being rude?
Huh?  :(
{I'm not certain what Facebook (where I've never been, btw), your career, etc. has to do with answering your question(s) regarding the Alpha 9500, its "value", and/or other amp choices....nor do I grasp what could have possibly caused my polite (but, direct and blunt) comments to be so misunderstood....but, those are really ancillary matters....what matters here is that I tried to help / you get the answers that you desire / and we all part as friends....in my opinion, anything else is just "noise"?}
Seriously, to be blunt....I think you completely misinterpreted my posting!
And, I truly regret that!
I think I'm a pretty decent guy, too... :)
And, I never for one second tried to "talk down to you"!
If that is how you perceived my attempt to help, there is nothing I can do now to "un-do" that....but..
But, if you do care to read the many other posts of mine, and/or drop me an email or phone call, I still wish to be of assistance.....(if you choose not to do so, no worries here)
Not to argue anything, but perhaps I should clarify?
You asked about the '9500....I (and others) answered you.
You asked for more but were not specific, so I answered you again with more info and mentioning that all I was able to do was answer in generalities as I didn't have any specifics.
I don't think there is anything wrong with any of that.
You seemed to take offense to my reference of the variety of questions to consider?
But, Rob, this wasn't meant as any personal attack ---- rather as a way to spur on some more specific info from you, so we could all provide you with further assistance.
Again, I think you simply misunderstood the effort that I was making to help.
And, that is regretful.  :(
Anyway, I do wish you well....and I do hope that whatever amp you choose you are happy with!
John,  KA4WJA
73 (really, best wishes!),
John,  KA4WJA
P.S.  Bob, I feel like I do need to offer one quick piece of context...
(I absolutely do NOT wish to sound braggadocios at all, so please forgive my words here!)
I have experience with HF amps for almost 50 years now, both tube and SS.....actually taught some CB shops (and one gentleman that went on to run a successful ham store) about neutralization, etc. as a teenager back in the mid-70's...
I've used 'em, repaired them, built them (homebrew and Heathkits), ranted about them, raved about them, questioned their IMD, etc, etc....
But, some of the others here have even more experience that I do!  I'm just the one that sometimes has the time to write on-and-on about them!  Hi Hi!
« Last Edit: October 14, 2022, 08:49:15 AM by KA4WJA »
KA4WJA
Re: Alpha 9500
« Reply #54 on: October 14, 2022, 06:09:41 PM »
To Bob, et al,
As I previously wrote, I still recommend the Alpha 77Dx, as my first choice for a reliable, clean, easy-to-tune, "brick-on-the-key", legal-limit amp.
If you desire to have an auto-tune amp, the Alpha 9500 is a nice choice...
(but, if you don't get satisfactory answers from Mike D. that he's well-capitalized enough and Alpha will be around for years....then it looks like you may wish to consider some "alternatives"...)
So, here 'ya go:
1)  Since I've called-out the K3 (and K3s) as being, in my opinion, a truly horrible rig (mainly in terms of transmit IMD), luckily it is not marketed as a SSB rig, and most K3/K3s owners are primarily CW ops....anyway, just saying it might come as a surprise to some here that, if you are looking for a SS amp, I'd actually recommend the Elecraft KPA-1500....(as well as the Expert 2K-Fa, that I mentioned earlier)...
{of course, I still like tube amps better....much better....but, if you're gonna' go SS, I'd look at the Expert 2K-Fa or the Elecraft KPA-1500...}
2)  Also, as some have mentioned OM Power and Acom, here are some comparison facts, and a couple brief opinions, regarding them....
In my opinion, both OM Power and Acom are good businesses....and good folks...
Both are modern private enterprises, that have shown the wonders of modern capitalist eastern European countries that were both former eastern-block communist countries....what a fantastic example of freedom!  :)
OM Power is now 18 years old.....with Acom being a bit older of an electronics and mechanical manufacturer, originally formed 1988 (just before the fall of the Berlin Wall), ten years later, in 1998, they debuted the 2000A HF amp...
3)  Both make grid-driven HF amps with overseas-made tetrodes....
OM Power uses the 1200w plate dissipation, Chinese-made FU-728f in the 2000A+/2501A+ (you can also get the larger Russian GU84b in the 2501A+, but apparently it makes the amp even louder?).....
Acom uses a pair of the 600w dissipation, Russian-made GU74b in the 2000A...(note the GU74b is a 600 watt diss tube, notwithstanding the erroneous misuse of the "4cx800" nomenclature, rated for ~ ">550w out"  www.ok1rr.com/tubes/gu74b.pdf  )...
As well as both also making other models of amps....with Acom also making a series of SS amps...
I have had friends with both, and they all say they liked 'em both....(although the edge goes slightly, to Acom)
Of course, if you wish for more headroom and you're still squeamish about the future of Alpha amplifier company....and you can deal with the cooling blower noise of the OM Power, then the OM Power 4001A at ~ $8800, with a pair of FU-728f tubes, is an option to consider.
4)  Here are three reasons that, if you exclude Alpha's and old Henry's from contention, the edge for a legal-limit HF tube amp, in my opinion, should go to Acom (see below, in #5, for details of why I have some concerns)....while both manufacturer's amp models work well, and both seem pretty well-made and heavy-duty....
a)  Acom does rate their 2000A as "no-time-limit" with its aux cooling fan (which may cause it to be as loud as the OM Power amps?)....
b)  Acom also mentions their "typical" 3rd and 5th order IMD of their 2000A, as -40db(PEP) and -45db(PEP), and the ARRL test results show  -37/ -60/ -61/ -60db(PEP) for 3rd/5th/7th/9th order IMD, which is not bad for a tetrode amp!
{And, with the ARRL's test report of the OM2500 (with a GU84b, rather than the more popular FU-728f) showing 3rd/5th/7th/9th order IMD of:  -43/ -44/ -60/ -56db(PEP)....}
c)  I haven't heard reports of high cooling blower noise from the Acom 2000A, as I have from those with OM Power 2000's / 2501's...(many say the OM Power amps sound like a jet engine is running in your shack!)
And, OM Power amps have a nice rep of being very loud / annoying....I have a friend ~ 75 miles from me, who actually built his OM 2501 into his closet, so he doesn't hear it!
5)  I try not to involve politics here (or anywhere except when filling out my ballot), but these days I'm making a personal choice to try to not buy any products originating from Russia, or products using Russian components (like those GU74b and GU84b tubes)...
{just my personal feelings here, I am NOT trying to argue this point, everyone has the right to their opinions and choices ...and, yes, I DO grasp that China is also, in almost any way you measure it, a ruthless, oppressive, totalitarian state...and yes, they have illegally ruled Tibet for decades, etc....and, I do try not to buy things made-in-China as well, but that is pretty darn difficult these days....and, they haven't attacked Taiwan, yet.... :( }
And, as the Acom 2000A uses the Russian GU74b tubes, this means I won't recommend it....but, that doesn't mean it's a bad amp at all!
Nor, does this mean you couldn't consider another Acom product, such as the manual-tune 2100A, with a 4CX1000a tube ---- although not my favorite tube (the 4cx1500b is a much better, more "linear" tube), you can get an Eimac or Chinese-made 4cx1000a....
Or, if you can deal with the blower noise, then the OM Power 4001A at ~ $8800, with a pair of FU-728f tubes, is an option to consider.
I hope this helps?
John,  KA4WJA
KA4WJA
Re: Alpha 9500
« Reply #55 on: October 14, 2022, 06:44:47 PM »
Jim,
Yep, I omitted the 4k ultra as it didn't have 160m....but, since it was made for > 11 years (versus the 4 years of the 3KD Premiere), I suspect there are not only more of them around to be found, but also possibly some that have had 160m added?
And, thanks for the inside info on the Henry 8K Ultra....I've only seen the control head in real-life, and all the youtube videos I've seen, have only shown it in operation, never the inside of it!  :(
I had an opportunity to buy one ~ 10 years ago, for $7.5k....I decided against it mainly due to its size and weight...(and, price)
And, now with your info, I'm damn glad I passed on that opportunity!
(and, I got my second 77Sx, for a lot less$!  with some NOS Eimac spares, too..)
And, I've never found a 3 minute warm-up to be an issue....but, again I'm not flipping things on instantly 'cuz I saw a "dx spot" for some rare country (obviously, I'm not a "dx'er", not a serious contester)...
So, I do understand that some others might find waiting 3 minutes to snag a rare one, only to find propagation changed, and/or now having to do battle in a pile-up, to be a pain-in-the-***.... :)
You forgot to mention the Henry 4 k ultra..with it's single 8877. But it only covers 80-10m.
IMO, the 8K ultra is a basket case. There are several versions of it. It's not engineered, it's ill conceived.  Ever worked on one?  It's a dog's breakfast.  If you do buy one, make sure it has the very latest upgrades done to it.  Those were done just before they stopped making it.   There is way too much to go wrong in that amp.
The 77DX has a 3 min warm up..and no auto tune / auto band switching.  Which is just fine for K3LR, who runs a multi -multi contest station.   IE:  all ampS tuned for CW...or tuned for SSB.   W3LPL uses monoband amps, that's even simpler and cheaper..at his MM contest station.   A slew of HB monoband amps is dead simple to optimize for each band.
And, over the past 40 some years....except for half-dozen+ field days, one 160m contest, and a few VHF contests....I'm not a contester....
So, while I know that every contact counts and QSO "rates" rule for serious contesters, is there really a "need" for an "auto-tune" amp?
Yes, I know it's "nice to have" (similar to "brick-on-the-key" being nice to have), but I'm actually asking a serious question, is an "auto-tune" a necessity for serious contesting?
(and, if so...what about any other operating?)
Just curious here....don't wish to stir-up trouble... :)
John,  KA4WJA
« Last Edit: October 14, 2022, 06:47:24 PM by KA4WJA »
Re: Alpha 9500
« Reply #56 on: October 15, 2022, 08:38:19 AM »
John,  KA4WJA
If you are jumping bands, or trying to snag a new multiplier on another band, you have 4 x choices, either an auto-tune amplifier, or a manually tuned amp that you just...'dial up by the numbers'...or a SS amp...or multiple amplifiers, each pre-tuned on a different band.   Pick one.
Re: Alpha 9500
« Reply #57 on: October 15, 2022, 08:43:37 AM »
'Brick on key'.... on paper, should be the most reliable of the bunch.   They won't run as hot using any mode, including RTTY / FT-8 / 10m FM.   When was the last time you ran a 1.5 kw CXR  24/7 ?
K7JQ
Re: Alpha 9500
« Reply #58 on: October 15, 2022, 09:01:02 AM »
John,  KA4WJA
I consider myself to be a pretty serious contester...95% of my operating...although generally not "in it to win it" due to antenna limitations (and operator proficiency ;)), and recently limited ability to keep my BIC (Butt In Chair). I just enjoy the rapid pace, contributing points to my contest club, and comparing my score to others in the club with more aluminum in the air. So, if I may offer my $0.02:
IMO, an "auto-tune" (tube) or a "no-tune" (solid-state) amp is not a *necessity* for contesting. But they definitely are a *convenience* in certain circumstances, especially quick band changes with resonant antennas. Whatever amp you use, the number one factor is reliability...the ability to be on for up to 48 hours and operate comfortably at or near its (conservative) power rating at high rate transmissions. After making all the preparations, there's nothing worse than to have your amp crap out and ruin your weekend.
Operationally, station efficiency is important if you want to keep up your Q rates. If your antennas aren't fairly broad-banded, you're wasting time having to constantly fiddle with and tweak a manual-tune amp's controls during wide frequency excursions within a band, especially in a CW/SSB multi-mode contest. An auto-tune tube amp (or SS with a built-in tuner) would be a real convenience if those excursions are within a 3:1 SWR range. Within a 2:1 range, a quality SS amp would be OK. If not in either of those SWR ranges, an external tuner would be necessary...more things to fiddle with and slow down your Q rate. Fast auto-tune antennas, like the SteppIR, would alleviate all those scenarios.
IMO, the less *mechanically* complex the equipment is, the better. I'd imagine auto-tune tube amps with stepper motors, and auto-tuners with relays would be more prone to failure over time. Other than T/R and BPF relays (that only operate with a band change), a SS amp would be less mechanical. Quality components are a big factor here. As John surmised, a brick-on-key, 24/7 amp would be "nice", but certainly not a major factor, as long as the amp is conservatively rated with decent power headroom to handle your desired modes. For ragchewing and DXing where speed and efficiency aren't really important, auto-tune, no-tune, or manual-tune amps?...take your pick.
One contester's opinions.
73, Bob K7JQ
N2WQ
Re: Alpha 9500
« Reply #59 on: October 15, 2022, 10:45:17 AM »
John,  KA4WJA
73, Bob K7JQ
Two words- remote operation.
A few more words- ability to place amp close to the antennas to reduce feed line loss.
Rudy N2WQ
Pages: 1 2 3 [4] 5   Go Up
