Author Topic: Uniden CR-2021/Realistic DX 400 repair  (Read 155 times)
KU4UV
« on: October 09, 2022, 03:09:47 PM »
Hello everyone,
Would a Uniden CR-2021/Realistic DX 400 shortwave radio be worth buying at $30?  The problem is there is no sound output, even though the radio powers on.  My first guess would be either bad electrolytic caps, blown JFET, or bad audio IC, but this is just a guess.
Has anyone in the forum ever recapped or worked on a Uniden CR-2021/Realistic DX 400?  What I should I look at replacing, and how difficult are they to recap?  Thanks!
Michael KU4UV
Re: Uniden CR-2021/Realistic DX 400 repair
« Reply #1 on: October 09, 2022, 04:18:35 PM »
Could be an open headphone Jack. May just need some cleaning at the jack contacts.
WB0CJB
« Reply #2 on: October 09, 2022, 05:38:25 PM »
Probably a bad transistor in the audio stage. I have a DX-400 and I found a burnt transistor, causing a no output condition.
One of these days I'll fix it. I'm too swamped fixing everyone else's radio.
Paul WB0CJB
KU4UV
« Reply #3 on: October 09, 2022, 06:24:57 PM »
Thanks guys!
« Reply #4 on: October 10, 2022, 05:49:00 AM »
Instead of buying broken radios, why not offer to do minor repair work at a local radio club?
You can start off with simple tasks and tackle tougher projects as you gain experience.
Many experienced repairmen have retired, leaving a big need.
Zak W1VT
KU4UV
« Reply #5 on: October 10, 2022, 04:01:14 PM »
Zak W1VT
I'm all for it for it, but I'm not an electrical engineer.  I know just enough about restoring old radios to be dangerous.  I can do the basics like check Voltages, replace bad electrolytic capacitors, etc.
« Reply #6 on: October 10, 2022, 04:07:01 PM »
I wasn't even a teenager yet when I did my first repair work.
Engineering skills aren't required for nearly all repair work.
The basics are more than enough to be useful.
Zak W1VT
KC3TEC
« Reply #7 on: November 04, 2022, 06:09:05 PM »
Zak W1VT
Correct!  Some Engineering skills are needed when designing equipment primarily because of the knowledge of how components interact determins the values needed to produce the expected results.
Repairing equipment requires methodic troubleshooting skills to determine the faulty component.
Identifying proper component or suitable alternate.
And proper soldering skills.
And a few good Elmer's or Elsa's around is always a benefit.
