I posted this on
https://groups.io/g/nanovna-users/ but no one has responded yet, so I am trying here. can't tell if this is the proper forum on eHam to post this.
Just bought a new nanvovna SAA2-N. Attempting to flash an updated firmware. I found it difficult to determine which firmware to use- I tried nanorfe-20220814-vna6000.bin then I tried nanovna-v2-20201013-v2_74.bin, but neither of them worked properly.
So I then I followed the instructions from DiSlord here:
https://github.com/DiSlord/NanoVNA-V2-firmware and had some trouble: got an error message saying "Unterminated quoted string". I then followed a suggestion from here:
https://github.com/nanovna-v2/NanoVNA2-firmware/issues/73 and then at least the compilation seemed to complete.
However, after uploading that binary.bin (using VNA_View-x86_64.AppImage) the device now just gives me a blank screen, regardless of whether or not I hold the button while turning it on. VNA_View now does not recognize the device.
When I plug the nanovna usb into my system Dmesg now reports:
[16007.201932] usb 2-1.8: new full-speed USB device number 8 using ehci-pci
[16007.617950] usb 2-1.8: device not accepting address 8, error -32
[16007.701947] usb 2-1.8: new full-speed USB device number 9 using ehci-pci
[16008.117962] usb 2-1.8: device not accepting address 9, error -32
[16008.118190] usb 2-1-port8: unable to enumerate USB device
Here is what I started with:
SAA-2N
SN: 3555144B-00043333-35343234
Hardware designed by OwOComm
Build Time: Jun 9 2021 -17:36:19
Compiler: gcc
Port Info: GD32F303
Board: SAA-2N
I am using an updated Debian system.
Can someone help me out of this predicament? Or did I just brick this new device?
Thanks if you can help,
Keith
