I use a keyboard w built-in pointing device. Both keyboard and pointing device (i.e., mouse) use PS/2 connectors. I presently use an adapter which employs an internal USB connection to convert the PS/2 input to USB. I've also used an external PS/2 to USB converter. Neither approaches are entirely satisfactory because, w W10 at least, the USB device doesn't always load reliably and boots w/o keyboard or, more often, a working mouse. A reboot usually sorts things out, but is annoying. This is never an issue on another PC w built-in hardware ports for PS/2 keyboard and mouse.
Can anyone recommend a good PCIe board which provides reliable hardware PS/2 ports for keyboard and mouse w/o any USB element? SIIG made one, and cheap knock-offs are available. However, not all seem capable of enabling the keyboard & mouse before the OS loads, which is essential to enter the setup BIOS.
Anyone use one of these adapters who can point me to a good one? The SIIG (PI2212-19G2A PCI TO PS/2 CARD MODEL JJ-PA0012-S1) is on auction at eBay, but I'm not clear if it will allow entry into the setup BIOS or not. The SIIG sites states "Note: Keyboard or mouse cannot be used in DOS using a bootable disk or for entering the system BIOS." The latter limitation would seem to be OS-independent, but maybe not. I fear off-brands would fare no better.
Many thanks.
