While operating 12 meter phone my 8410 suddenly powered completely off. After turning the power switch off and back on the amp went thru its usual warm up process, after 3 minutes the amp was ready to place in the operate position, when trying to tune the amp there is no output and it goes in the fault mode. The HV led is maxed out and the IP led is 0. The gain also shows 0.
At the time it tripped out I was only running about 700 watts.
Any ideas where to look.
David KE4YD
