Author Topic: Ameritron pulser ATP-102 question  (Read 255 times)
KD0VE
« on: November 02, 2022, 04:07:38 PM »
picked up an Ameritron pulser ATP-102 for almost nothing off craigslist.  Before I connect it to any of my equipment how might I check the output?  I do not have a scope although I do have access to one at the ham clubhouse if thats the only way to check the output.
thx to anyone taking the time to offer advice.
Re: Ameritron pulser ATP-102 question
« Reply #1 on: November 02, 2022, 04:24:41 PM »
The only thing that will work is either a scope, or better yet, a PEP wattmeter.  I believe the Ameritron unit plugs into the CW key jack. I think the pulse rate can be changed (use the fastest speed)...and also the spacing between pulses
(changes the duty cycle).
« Reply #2 on: November 02, 2022, 04:54:06 PM »
Check it with an ohmmeter across its key output. You should see it tick between infinity to some intermediate value when the pulser is operating.
N2SR
« Reply #3 on: November 03, 2022, 04:57:05 AM »
a keyer set to 50 wpm wouldn't work
Elect a clown.  Expect a circus.
« Reply #4 on: November 03, 2022, 08:50:34 AM »
Sure it would. It's done all the time.  Dots at 30-60 wpm result in a 50% duty cycle on the plate current side of things.
 On my yaesu MK-V's, the weighting can be changed from A-Z.  With that tweaked, the duty cycle can be reduced down to abt 20-25%.
N2SR
« Reply #5 on: November 03, 2022, 04:24:47 PM »
no kidding.
psst.  that's the sad part of the OP's post
« Last Edit: November 03, 2022, 04:27:33 PM by N2SR »
KD0VE
« Reply #6 on: November 04, 2022, 06:24:21 AM »
everyone thx for the help. it works fine.
« Reply #7 on: November 04, 2022, 08:12:55 AM »
On my Icom rigs (7300, 7610) I programmed one of the CW memories with a long string of e's
When the keyer speed is turned up you can just push one button and then tune up a tube amp as the series of e's play out of the rig. I am sure you could do this with other rigs that have CW memories.
