This is a new one on a me. I need to replace the pl-259 connector on my Hustler MBM mag-mount base. I took the the base to the local CB shop, because I don't currently have a crimper or connector, and I thought they could put another connector on it for me. The tech at the shop told me that he never replaces connectors on mobile antenna bases, because the SWR is never right again when you replace the connector or coax. He told me that essentially, you just have to purchase a whole new base, as the SWR (I guess he means for the cable length) is set at the factory. This seems strange to me, and I have never heard of this. It would seem as long as your SWR looks good when you replace the connector or just put a similar length of coax on the base, that you should be good to go. I called Hustler, and they said the same. Any thoughts on this one? Thanks!
KU4UV
