I have a Flex 6500 and Windows 10 computer. I have been using the full, licensed version of VARA in Winlink for some time now and it has worked well.
Now, I wanted to try VarAC. I have a really basic question for you on this VarAC.
I had a VARA HF running successfully in the past for my Winlink (v4.6.1) it was in a folder labeled VARA
When I downloaded VarAC, I put it into its own folder. I think that was wrong and the reason it could not find the .exe file.
Tonight, I unzipped the VarAC zip file inside the original VARA folder. Then, I tried to configure it for rig, etc. I tried both Flex and Kenwood Generic. Now, I get a different error code: "ADIF File Misconfiguration - ADIF File Directory does not exist"
Was I supposed to install this new program (VarAC) inside the existing VARA folder? The reason I think so is, in Settings - VARA file path, it shows "C:\VARA\VARA.exe which is the executable for the original VARA program.
Has anyone successfully installed VarAC on top of VARA and configured it? Many Thanks, Jim KD1I
