Pages: 1 2 3 [4] 5 6 7 8 9 10   Go Down
Author Topic: Greyline Vertical issues  (Read 2416 times)
Re: Greyline Vertical issues
« Reply #45 on: December 09, 2022, 05:11:02 AM »
After a fresh read of this thread I decided to investigate the potential of this concept to produce the performance expected for it.  The results are shown below.
Conclusion reached after doing so: Yes, and the system could perform much better than the results being posted for it in this thread if the installed design consisted of the configuration in this study.
This antenna system has and needs no path to Earth ground or to buried/elevated radials to do so, although a static drain choke and transient suppressor could be used, and would not reduce system performance to any practical degree.
The gain/performance of this system (-5.6 dBi) is much better than this clip from the link to Owen Duffy's comments earlier in this thread:  \\The NEC model of the antenna at 3.6MHz suggests gain is perhaps 15dB lower than claimed by some and some 25dB poorer than a lossless monopole antenna system.//
« Reply #46 on: December 09, 2022, 05:16:22 AM »
That particular ATU can be isolated from RF GND at the input or at the output. Since you have an output choke it is logical to isolate the tuner at its output. If you want to isolate it at the input you can wind a choke using 9 turns of RG-58 (or RG-400) on two stacked FT240-31 cores. The choke is mounted at the antenna tuner input.
Can you install ground radials? If so, the antenna can be reconfigured as a 28' vertical working against earth GND as described earlier. It should tune 40-10, probably 80 (my 34' vertical tuned quite well using the MFJ-993BRT) and will not tune on 160 meters using any ATU I know of. For 160 meters an 80 uH series inductor can be installed at the base of the 28' vertical (between the vertical and the ATU). It will not be very efficient -- just a few percent -- but it will make QSOs on CW and FT8.
G3TXQ chokes  http://www.karinya.net/g3txq/chokes/type31.jpg
Yes, ATUs can be temperamental. Switching the DC power ON/OFF is a normal part of using MFJ remote ATUs.
Low Band Steath
Low bands using stealth antennas has been my "thing" for the last two decades. These have included 160 meter antennas from 12' tall to 38' tall as well as many full size cover-of-darkness antennas. The 38' tall, top-loaded vertical achieved ~20% radiation efficiency and was stealthy in that it tilted up under cover of darkness. The 12' tall was also top-loaded and it too could only appear at night. Balloon antennas were used in several 160 meter contests.
My most versatile stealth antenna was based on a Tarheel 200HP mobile antenna mounted inside a hollow 4" x 4" vinyl fence post. A bird house was mounted at the top to complete its disguise. During the day a 3' whip allowed operation on 20-10 meters. Various whips were used in the evening with the longest being 24 ft. This made the antenna a 29' base-loaded vertical worked against 90 radials covering a 25' x 50' backyard. Radiation efficiency on 80 meters was around 50% and with 1200W it worked all continents from Utah. On 160 meters it was not very efficient but with 1200W It was fun in contests.
Your Antenna
What can be done with your 28' vertical? Base-loading it with the ATU, or a loading coil, can make a 25% efficient 80 meter antenna given base-referred GND resistance + loading coil loss of 15 ohms. Adding a 47' long #26 horizontal top wire makes it into an inverted-L having 60% radiation efficiency. This antenna has 4 dB of gain over the 28' vertical. The top wire could be dropped during the day and pulled up at night. You can configure the 28' vertical for 160 meters and make contacts. It won't be very efficient but it will work.
« Last Edit: December 09, 2022, 05:37:55 AM by KH6AQ »
« Reply #47 on: December 09, 2022, 06:05:45 AM »
Tim, I'll work with you to optimize your vertical for low band performance. The design space can be whatever you like working with these tradeoffs: budget, performance, ease-of-band-change, ease-of-build and esthetics.
« Last Edit: December 09, 2022, 06:09:20 AM by KH6AQ »
« Reply #48 on: December 09, 2022, 09:58:48 AM »
Do you think a top hat would attract too much attention?
The MFJ-1792 80/40 meter vertical is a good example of 80 meter top loading. At the top of the vertical (your 28' vertical would work) there is a loading coil and six 27" long spokes. You can roll your own using PVC pipe, #14 THHN wire, and stainless steel threaded rods from a hardware store. Simple, inexpensive and easy enough to tune. Add a 40 meter loading coil at the base and you have 80/40 meters with automatic band switching, no ATU required. With a 15 ohm base-referred GND (easy to achieve in my experience) the radiation efficiency is 45%. It is about 3 dB down from a full size 80 meter vertical. On 40 meters radiation efficiency is 57%. Efficiency can be increased with more radials in the ground.
Another example of an 80 meter top hat and loading coil is the DX Engineering Hot Rodz™ capacity hat. Added to a Hustler RM40 or RM40S resonator it forms an 80 meter top hat and like the other top hat it can take the legal power limit. With a small base loading coil (~3 uH) you have an automatic band switching 80/20 meter vertical. Using an ATU at the base it may be able to tune the other HF bands.
A top hat can be constructed for 160 meters but it's not small. The smallest uses a Hustler RM80 resonator a Hot Rodz™ capacity hat with six spokes around 6' long. The SWR bandwidth is <15 kHz and radiation efficiency is in the few percent range. A base ATU will tune it across the 160 meter band. I've had great fun in 160 meter contests running QRP to such an antenna from Utah. I have used similarly inefficient top band antennas here in Hawai'i and made contest QSOs at 100W.
DX Engineering Hot Rodz™  https://www.dxengineering.com/parts/dxe-hr-2p#overview
MFJ-1792                           https://cdn.shopify.com/s/files/1/0289/7782/3843/files/MFJ-1792.pdf?v=1586534137
« Last Edit: December 09, 2022, 10:06:20 AM by KH6AQ »
WA5YOM
« Reply #49 on: December 09, 2022, 12:27:19 PM »
As far as what will gather attention....well I am not sure.......since at this point in time.....I haven't homed in on a particular home......I am looking for a "no-hoa" neighborhood.....but even so....antenna structures are not allowed based on some restrictive covenants...so, I am trying to be proactive by having a antenna solution before I move......
As far as installing radials, etc....I don't have a problem with that......
I need to double check the height of the vertical......
I figured the "flagpole " vertical would be installed in the backyard,,,,where ever I go.....and that is the case with my current installation......
As far as testing alternatives using the existing structure, I don't think that would be hard to do.....I already have the ground rod installed.....it would be relatively easy to switch back and forth between the original design and other options...
I am mostly interested in the low bands......since wire antennas......maybe installed in an attic might work fine for 20-6.........or....maybe two verticals......to cover everything.....
I would like to see if there are any improvements we can make to the existing design first....before I start modifying the entire design concept.......in the mean time, if radials are needed for experimentation.....I could start preparing for that.....
« Reply #50 on: December 09, 2022, 01:14:03 PM »
That sounds good. A loading coil can be added between the ATU and the ladder line feedpoint to help out the ATU. 17 uH resonates it near the 40 meter band and may be enough to help the ATU tune 80 meters easily. It changes the 3.5 MHz input Z from 6 -j1600  to 6 -j1250 ohms. 75 uH resonates it at 3.5 MHz but raises the 40 meter reactance to where the ATU might not tune on that band.
I can work on this some more after the 10 meter contest this weekend.
W3SLK
« Reply #51 on: December 10, 2022, 07:26:59 AM »
If you ultimately end up in a 'NO HOA' residential area, erect your antenna and leave it up for a few months prior to using it. Make sure everything is disconnected. As soon as your aerial is spotted truth be told someone will complain about hearing strange things in their TV or computer. The finger will be automatically pointed at you. That's when you can show them nothing is working yet! I had to do that a few times.
« Reply #52 on: December 12, 2022, 06:19:03 AM »
The MFJ-993BRT ATU had trouble finding a match on some bands when feeding a 34' vertical when there was a short coaxial cable between it and the antenna. Connected by a 2' wire it worked fine but connected by a 2' coax was not. It seems the shunt capacitance of the short, low-Z cable may be the issue into the non-resonant antenna. A balun between the ATU and the antenna adds a short low-Z transmission line. So, it could be better to connect your antenna ladder line directly to the ATU random wire and GND posts with a 1:1 CM choke on the input side of the ATU. Being that the ATU uses the coax for both the RF and 12V this can be done by winding a 4 ft. coax jumper on two stacked FT240-31 ferrite cores. I'll model this to see what the core dissipation is at 1.5 kW.
« Last Edit: December 12, 2022, 06:21:39 AM by KH6AQ »
WA5YOM
« Reply #53 on: December 13, 2022, 06:30:24 AM »
I was going to insert a picture of the connections but I haven't figured out how to insert a picture......
So, currently.....the ladder line is connected directly to the ATU....
The choke balun is connected to the transmitter side of the ATU,,,,,at the antenna......the coax is about 60'.....and runs to a mfj window feed through...the window feed through is grounded....I have a manual antenna switch that selects one of two positions...one position goes to the greyline....the other to my other local atu.......
I think my preference...at the moment is to see what can be done to get thew vertical tuning on 80.....
I need to add lighting protection......and maybe another choke balun in the shack......
I can make a loading coil.....but if there is one commercially made....that is my preference...
Tim
« Reply #54 on: December 13, 2022, 09:03:15 AM »
The balun has two stacked cores and if they are FT240-43 type the G3TXQ shows the common-mode impedance to be 4-8k ohms on the 80 meter band. It's probably a good balun for your antenna. I know what you mean about posting a pic here. I haven't been able to figure it out. I have to provide a link to a pic on IMGUR.
G3TXQ FT240-43 core chokes   http://www.karinya.net/g3txq/chokes/type43.jpg
Loading Coils
The ATU might tune fine on 80 meters with an added series loading coil at the ATU output. I would start with the 17 uH coil first because that tunes it near the 40 meter band, hopefully allowing the ATU to tune 80 & 40 meters. It may not tune on some of the higher bands as I found out with the 34' vertical. If that works for you you can stop there. If it still won't tune on 80 meters a 75 uH coil is the next thing I'd try. I would connect the coil to the side of the ladder line connecting to the lower antenna tube. Or, flip a coin and connect the coil to either wire.
The coils are so easy to build that even I can make one and I wound four recently for a 160 meter receive antenna. I close-wind (turns touching) #14 THHN (house wire) wire on PVC pipe. With turns touching the pitch is 9-10 per inch. I find stranded wire is easiest to use. An 1/8" hole is drilled at each end of the coil form to hold the wire on the form without tape or glue. To wind a coil push whatever lead length of wire you want through one hole from the outside and feed it out the end. I then rotate the form, winding the wire tight with turns touching. When the turns get to the hole at the other end cut the wire and push the lead thru from the outside and pull it out the end of the form. This makes a nice, neat, almost professional looking coil.
You can use different wire and/or a larger PVC pipe if you like and find the hole spacing using the pipe dimensions and inductance links below. Another way to go is to wind up a random coils give them a try.
Materials
PVC pipe, schedule 40, white, 1-1/2" (OD = 1.9")
#14 stranded THHN wire (house wire)
17 uH: drill holes 2.5" apart and there will be approximately 25 turns of wire
75 uH: drill holes 9" apart and there will be approximately 90 turns of wire
PVC pipe dimensions   https://www.pvcfittingsonline.com/resource-center/pvc-pipe-dimensions-18-through-24/
Online Solenoid Inductance Calculator   http://electronbunker.ca/eb/InductanceCalc.html
« Last Edit: December 13, 2022, 09:11:46 AM by KH6AQ »
KA4WJA
« Reply #55 on: December 13, 2022, 01:58:32 PM »
Dave,
These words of yours here (especially those I highlighted in bold type) are so very true!  :)
And, is something that I have been saying for decades now!
I know that some of the modeling experts out there can show models until the sun no longer shines, but the fact is the myth that you can feed a random wire antenna, with a coax (from a tuner) and not lose significant performance and/or not have tuning issues is something that I've been trying to propagate for many, many years (decades).
{ever since my first remote-tuner random-length wire antenna (a non-res vertical wire on a boat) install assist, as an adolescent, in 1973, I've been using GTO-15 wire (or other well-insulated / well installed wire) on the tuner output.....and, while we never saw anyone even attempt using "coax" until the past 20 some years, (when modern GPS, etc., gave many their easy entre' into offshore sailing, etc.), over the past couple decades I've seen many try to use coax out of an Icom AT-130/At-140 (or AH-2 or AH-4), etc....and simply replacing it with a length of wire (GTO-15 or otherwise), they see significant improvements in both their transmit performance and tuner's abilities....(....and surprising to many even improvements in rec s/n, mainly 'cuz they have RFI-producing devices within feet or inches of their radio, tuner, and/or antenna)....and, with the questionable tuning ability / lossiness of an MFJ tuner (torroids and cermanic caps, I think....rather than the air-wound copper coils and silver-mica caps of the Icom tuners), trying to use coax on the tuner output, can run into some serious issues...and, I think Alan, K0BG, has also found many HF Mobile installs trying to use coax out-of remote tuners, as well....and he always mentions this as a big mistake!}
This is also why I try to point out to folks that placing a balun (or unun) on the tuner output (antenna terminals) is a bad idea!
And, try to recommend that they use a common-mode-choke / "line isolator", on the coax on the input (radio side) of the tuner....to keep the coax from radiating, etc...
Of course if using these single-ended tuners with balanced feeders on the output, some think this requires a "balun", but I've found this to be a mistake....use the tuner "output" and "ground" lugs to feed the open-wire-line and you're good as far as the antenna and tuner is concerned....
And, here again I  try to recommend that they use a common-mode-choke / "line isolator", on the coax on the input (radio side) of the tuner....to keep the coax from radiating, etc...
Anyway, Dave, I just wanted to say Thank You for mentioning this here!
Some folks get too wrapped-up in the "common-mode" issues that seem to propagate our ham discussions these days, they forget that the main role of the antenna system is to radiate the transmitter power as efficiently as possible / efficiently receive signals as exclusively from the antenna as possible....and, trying to feed the antenna with coax from these single-ended tuners and/or adding a "balun" or CMC on the output of a single-ended tuner to a non-res antennas is a very bad idea!
Fair winds Tim, and good luck to you on your antenna project (and yes, keep the choke on the input [radio side] of the tuner)
John,  KA4WJA
P.S.  as for "adding an image"?
Easy-peasy...
Here is the inside of the Icom AT-140:
« Last Edit: December 13, 2022, 02:09:26 PM by KA4WJA »
WA5YOM
« Reply #56 on: December 13, 2022, 05:32:15 PM »
Yeah...I can make the coils......not a problem.......have a lot going on at the moment.....with the Christmas season...and I am doing major remodeling on the house........in fact....the people at Lowes...think I work there...since I am there so much.....I have lots of extra wire laying around......mostly solid romex.....though.....may have some stranded...will have to take a look......
I will build both coils.....so it will allow for more thorough testing...
Well...I am glad someone knows how to post a picture......
thanks,
Tim
wa5yom
« Reply #57 on: December 14, 2022, 05:14:31 AM »
Most of the modeling efforts will not reflect the field conditions. When you drive a highly unbalanced load directly with ladderline, the ladderline itself becomes imbalanced. The ladderline is therefore no longer acting as a transmission line but rather as an active radiating/receiving part of the antenna.
Placing a balun at the input to the ladderline will not correct its imbalance. Normally the balun (common mode choke) should be placed between the ladderline and the antenna. This will largely correct any imbalance due to the imbalanced galvanic load but it will not correct the effects of the imbalanced near fields of the antenna on the ladderline.
Even with a balun at the antenna, the unbalanced tuner will require another balun to feed the ladderline. This proliferation of baluns suggests that replacing the ladderline with coax may simplify the installation and result in potentially lower losses.
Some pictures of the installation would certainly help. If the OP cannot post pictures, please email them to me at my call at arrl dot net and I will post them for you.
« Reply #58 on: December 14, 2022, 09:47:37 AM »
The ladder line appears to be routed down the inside of the bottom Vertical Dipole tube. Greyline recommends a balun on the remote ATU input side. They claim that even the 20' version will tune on 160 meters. I don't see how this is possible with all of the remote ATUs on their list. Tuning the 28' Vertical Dipole on 80 meters is pushing things as you've discovered. Tuning a short vertical against a single 3' vertical wire seems like a challenge.
Configuring your DX Flagpole
   https://greylineperformance.com/blogs/news/correctly-configuring-the-flagpole-tuner-and-balun-feed-system
Greyline 28 Foot vertical dipole assembly guide
   https://cdn.shopify.com/s/files/1/0028/2571/5779/files/28_Foot_DX_Flagpole_Instructions.pdf?v=1663711590
AC6LA
« Reply #59 on: December 14, 2022, 03:22:20 PM »
Pages: 1 2 3 [4] 5 6 7 8 9 10   Go Up
