It should just slide off, some of them were always tighter. Dont undo the join to open it up, that will ruin it. If the valve is duff, then you can be a more vigorous it getting the cover off.
Mind the glass and your fingers.
From memory the tight fitting ones were meant to aid cooling.
Cheers Gavin.
