:)You are on the right path.
The idea is the neutralise the internal capacitances of the tubes by applying negative feedback via the neutralising cap.
This will stabilise the finals and stop runaway oscillations.
Remember to turn off Screen Grid switch on back panel after tuning up rig on 10m into dummy load.
At this frequency the adjustment will be most effective.
So then there are two ways: monitor that frequency on ssb on another rig with attenuators engaged, and perhaps fly lead over coax to dummy load into that radios antenna socket.
Send small (very low) carrier on tune position on your Hybrid, and tune other radio till you get heterodyne beat audio and S meter deflection.
You might have to add / remove att. for proper deflection, around mid scale.
Adjust neut. cap. for minimum deflection on S meter.
A better way and easier, is to connect 10 times probe and scope to hybrid antenna socket with dummy connected, TX with either low or no carrier on ssb, turn neutralising cap for minimum deflection on scope.
Remember scope must be adjusted for decent deflection on carrier and noise for adjustment.
After adjustment, remember to switch on Screen Grid switch again.
Use as little carrier on tune pos as possible to give good deflection on scope.
Be careful with Neutralising cap, use insulated tool, and don't force it.
73 de William
ZS4L / ZS5WC
Thank you.
So my only option will be option #1...using the other receiver.
As a test, I have another kenwood hybrid, that works fine...and I went thru the process of tuning to 28.5 into a dummy load....and then I flipped the SG switch to the down (off) position on the hybrid...so the settings on that rig were lower left knob set to tune (as opposed to cw, usb or lsb)....and the meter knob on the upper left by the meter set to RF (as opposed to ALC or IP or HV)....
and on my receive rig (an icom 756 proii) I tuned to 28.5, unplugged the antenna, put that rig on CW...I also put my RF/SQL knob to 12 o'clock position (the way I have that knob functioning is both RF and Sql....at 12 o'clock RF is full (open/loudest) with no blocking - if I moved the RF knob counter clockwise from 12 oclock towards say 9 oclock, it begins to block noise......(at 12 oclock there is no squelch)
when I hit the send on the hybrid, I did hear the tone on the rx rig....and I had some meter deflection...
so I'm guessing when I go through this same process with the hybrid I'm putting new tubes in, as I slightly turn that adjustment screw to the left and right, I will see the meter go up or down on the rx rig (icom)....and my goal is to stop where I get the lowest meter (s unit) deflection...
I did fabricate myself a screwdriver out of a 12" wood dowel...and I put some resin (thin coat) down by the last few inches for strength...I tested it before applying the resin, with the rig off so no shock danger, and was able to turn the screw back and forth without any negative effect to the wood dowel tip...so I'll use that when I make the adjustment.
If I have any of this wrong let me know...but I think I understand it now...
Thanks so much!
