Author Topic: 10 kw CCS on 6M..using the 3CX-6000A7...Part 11  (Read 146 times)
« on: November 22, 2022, 01:34:23 PM »
Here the paralleled, high power RJ2B output relays are installed on a custom bracket.  RG-400  teflon coax is used for the bypass leg. It goes through a grommet..and terminates on the smaller input  RJ1A vac relay.  More RG-400 tefon coax from input SO-239 connector...to the same RJ1A input relay.  SFT-600 teflon coax (blue) used between the pair of output relays...and the output coax connector...which is a  7-16 DIN  female type.  The output relays coils are wired in parallel, with the back emf diode across one of the coils.  This completes the vac relay installation and wiring.  A total of 4 x vac relays are used. (1) input.  (2) cutoff bias. (3+4) paralleled output relays.   The feedthrough (bypass)  swr will be measured,  and a compensation cap installed to cancel out residual  XL.   SFT-600 teflon coax is the teflon version of LMR-600..and dwarfs RG-393.
 https://www.youtube.com/watch?v=Jt7Iv8X84lY
