Author Topic: Which forum for Equipment post?  (Read 54 times)
K4BDA
« on: November 23, 2022, 01:30:08 PM »
I need suggestions on selecting equipment.
Which forum is appropriate for this?
Will, K4BDA
K4GTE
Re: Which forum for Equipment post?
« Reply #1 on: November 23, 2022, 02:01:37 PM »
It depends on what type of equipment. If you go to the main header "eHam forums" you'll see all the different forums. Amplifiers, transceivers, etc. "Elmers" and "Misc" also work.
K4BDA
« Reply #2 on: November 23, 2022, 02:51:12 PM »
In particular I'm looking for suggestions on finding a stand-alone transmitters... not a transceiver.
Which forum would you suggest for asking for suggestions on that?
Will, K4BDA
KC3TEC
« Reply #3 on: November 23, 2022, 03:42:28 PM »
Will, K4BDA
That depends on the bans you want to use.
You can home brew or purchase kits.
Generally your not going to find a newer prebuilt transmitter very often but you may find used transmitters.
There are sites such as qrpme.com, qrpguys, qrplabs, and a few others where you can purchase easy to build kits but they will usually be 5 watts or less.
There is also qth.com ( ham classifieds)
N7EKU
« Reply #4 on: November 23, 2022, 03:44:47 PM »
Will, K4BDA
I would put it on the "Station Building" section.
73,  Mark
Mark -- N7EKU/VE3
