I am puzzled about the Audio Peak Filter (APF) for CW on my FT-891. It is not clear to me what parameter the setting (-250 Hz to +250 Hz, with default value of 250 Hz) refers to.
If it is some width I would not expect to be possible to set to a negative value. On the other hand, if it is some shift I would expect the default to be 0 Hz and not 250 Hz.
Moreover the manual says that “The APF bandwidth can be selected narrow/medium/wide with the menu item 12-01 [APF-WIDTH]." Which is the relationship between this setting and the -250 Hz to +250 Hz setting?
Does someone knows more about this function?
I usually don’t like just to try and see if a function works without knowing what it actually does! But this is a limit against ham radio, I know...
