Author Topic: Ameritron AL-80A HV Question  (Read 267 times)
N5XJT
« on: November 26, 2022, 11:26:16 AM »
I purchased a used AL-80A (1990 mfr.) about 2 yrs. ago and so far very happy with it, no problems.  Output checked with 3 different watt meters so confident this is correct, around 850 watts CW and 1KW+ ssb with 60 watts input from either a FT-950 or a TS-850. The tube is a Chinese RF Parts 3-500Z about 15 yrs. old. HV is 2900 stand by, fairly steady under transmit. Question:  Is the 2900 HV indicative of a possible problem as the manual states it should be around 3100?  Just being over cautious, any thoughts appreciated.
W1QJ
Re: Ameritron AL-80A HV Question
« Reply #1 on: November 26, 2022, 12:02:37 PM »
HV is dependent on you line voltage and the condition and accuracy of the series resistors.  Most likely everything is totally fine.  Manual states a nominal value. YMMV.
« Reply #2 on: November 26, 2022, 12:54:15 PM »
Hv is dependant on line voltage, as Lou said.
Metering accuracy is dependant on resistors installed in the 80s/90s....  Not sure when they went to the B model.
I found my Sb220 was very low HV.....  Or. So I thought.
Once I replaced all metering resistors my HV jumped up 400 volts!
KM4AH
« Reply #3 on: November 26, 2022, 01:11:30 PM »
If it doing 1000+ with 60 watts drive there is nothing off about your voltage. Not, sure about your watt meter.
W1QJ
« Reply #4 on: November 26, 2022, 03:44:50 PM »
The watt “indicator” on this amp is NOT a watt meter.  It’s never exactly right at all and can be way off from a true value. It’s an TF voltmeter and usually calibrated on 20 meters into to a 50 ohm resistive dummy load.  It’s good for seeing a peak in output while tuning up but accuracy isn’t that good.
N5XJT
« Reply #5 on: November 27, 2022, 06:46:52 AM »
Thanks for the replies, good info.  I never thought the built in watt meter was accurate so I verified output with three different external meters.  Sounds like all is well so will leave as is.  Thanks again.
Joe - N5XJT
KM4AH
« Reply #6 on: November 27, 2022, 12:18:36 PM »
Well, that's better than 12 dB gain. Which is really good.
