Author Topic: Anyone familar with D&A PHANTOM Triple Stage AMP ?  (Read 325 times)
K4RKX
« on: November 27, 2022, 11:22:14 AM »
I was looking at linear amps in the 2000 watt or less for DXing, and remembered this one from a child.  It says 10 15 20 and 40 meter and is listed as a Ham Linear Amp but not too sure.  It may be a amp used on 11 meters or "cb"...  Does anyone know?  I need some guidance as I do not want to damage the ic7300 or the AT2K antenna tuner by "trying" it.
W3PX
Re: Anyone familar with D&A PHANTOM Triple Stage AMP ?
« Reply #1 on: November 27, 2022, 12:11:30 PM »
I found a description of one online that stated it was designed for an input drive level of 4 watts. I think we all know what that means.
"So, we just went ahead and fixed the glitch" - Bob Slydell
"I’d say in any given week I probably only do about fifteen minutes of real, actual, work" - Peter Gibbons
W5GA
« Reply #2 on: November 27, 2022, 04:14:22 PM »
The multi band marking was done by 70's/80's CB amp manufacturers to keep the FCC away.  Don't even think about it.
W3PX
« Reply #3 on: November 27, 2022, 04:23:14 PM »
And some manufacturers of these "multi band" amplifiers kept the deception going by installing a non-functional band switch with a hard wired single band tank circuit tuned for 11 meters.
K4RKX
« Reply #4 on: November 27, 2022, 07:21:06 PM »
Yep.. what i thought..   i guess im now looking for a LDMOS solid state amp.  I appreciate the quick replys... I was told very similar info..
