Author Topic: TX Time Out on Yaesu FT-70DR  (Read 106 times)
K1KIM
« on: November 28, 2022, 08:39:30 AM »
Of all the 64 menu selections on the above HT I can't seem to find the TX Time Out menu function. It seems I am dropping out after about 10 seconds.
Can anyone point me to the correct location?
K1KIM
Re: TX Time Out on Yaesu FT-70DR
« Reply #2 on: November 28, 2022, 09:04:47 AM »
https://www.yaesu.com/downloadFile.cfm?FileID=15143&FileCatID=263&FileName=FT%2D70DR%5FDE%5FAM%5FENG%5F1907%2DF.pdf&FileContentType=application%2Fpdf
See customized menu settings. It’s there.
I have read that several times and am still drawing a blank as to which item # it is.
Care to clarify?
WA3SKN
« Reply #3 on: November 28, 2022, 09:17:04 AM »
10 Seconds sounds more like a low battery or high VSWR issue.  Do you still have the same issue when using low power into a known good dummy load?
-Mike.
WA1LAD
« Reply #4 on: November 28, 2022, 09:18:14 AM »
Item #56 on page 41 in the manual.
Enjoy!
K1KIM
« Reply #5 on: November 28, 2022, 10:00:28 AM »
Enjoy!
I thought that was it, but I only looked at the quick guide of the menu and not the full description on page 41. TOT was not very descriptive on the quick guide.
Thanks for the info.
