Author Topic: DELL COMPUTER  (Read 303 times)
N4MJG
DELL COMPUTER
« on: November 29, 2022, 01:47:30 PM »
I HAVE DELL DESK TOP  WITH CD OR DVD I DON'T REALLY REMEMBER HEN I PUT TIGARTRONIC SOFTWARE IT CAN'T OPEN THE SOFTWARE SINCE MY RECENT STROKE IN 2019 I DON'T REALLY REMEMBER AT HOW I GOT IT GOING OPEN THE SOFTWARE SO I CAN DOWNLOADED THE DIVER FOR THE USB.
Jackie
N4MJG
JACKIE GREEN
LA9XNA
Re: DELL COMPUTER
« Reply #1 on: November 29, 2022, 03:32:49 PM »
I assume you ar erefering to the Tigertronic signalink digimode interface.
This is basically just a USB soundcard with transformer for galvanic isolation on the audio and electronics for keying the tranciever.
To get the driver you will only have to connect the inteface with a USB to you computer ant then windows will download the driver automatically.
To check if the interface is connected to the PC propperly and working as a soundcard you can do the following.
1. Press down the windows key to open the start meny.
2. in the search field type "Device manager" and click on the text.
3. Click on the "sound, viedeo and game controllers" dropdown.
4. Plug the Signalink in the USB on your PC and see if there pop up a new device in this dropdown.
    If not there will normally come upe a icone in the meny that is a yellow trianlge. Click on this dropdown and right click on the first yellow triangle
    select "Update Driver Software" redo this untill all the yellow triangles are gone. Then unplug and replug the SL as described in paragraph 4
The SL does not have a dedicated software form Tigertronics but i have added some links further down on where you can download some software.
I would reccomend you to use the Fldigi software becaue it is pretty simple to set up and you can find a lot of information on the internet on how to set it up. Its also free.
Signalink page. https://www.tigertronics.com/slusbmain.htm
Signalink link page for 3 party software. https://www.tigertronics.com/sl_soft.htm
I would reccomend if you get problems setting this up that you ask an local HAM, wife, kid, neigbour to give you a hand setting up the interface and software.
Hope this will get you back on the air  :)
PS!
Be sure that you got the correct interface cable for your tranciever.
Looking at your pofile on QRZ.com assuming this is for one of your yaesu radios it is most likely a mini Din connector.
« Last Edit: November 29, 2022, 03:35:23 PM by LA9XNA »
AC2EU
    • McVey Electronics
Re: DELL COMPUTER
« Reply #2 on: November 29, 2022, 04:50:26 PM »
looks like many "generic' apps will interface with the signal link devices , if you configure it correctly. ( I don't own one)
You might find the instructions here helpful:
https://www.tigertronics.com/pgmsetup.htm
N4MJG
Re: DELL COMPUTER
« Reply #3 on: November 30, 2022, 08:10:42 AM »
XNA,
 ALREADY TRY THAT NO LUCK ! YET IF I CAN CD OPEN THE SOFTWARE THATS HOW I FIX LAST TIME I USE LAST TIME WAY BEFORE 2019 STROKE WHICH I CAN'T SE TOO WELL I ONLY WHAT I CAN DO MY LEFT SIDE OF MY BODY IS USELESS ! BUT TRYINGAND BLIND RIGHT EYE
PS!
JACKIE GREEN
Re: DELL COMPUTER
« Reply #4 on: November 30, 2022, 09:04:44 AM »
Jackie,
Once you use the CD or DVD you should not have to use it again.  The software that runs the Tigertronics interface is off-loaded into the computer.  You shouldn't have to use the CD/DVD again.
To try this, just plug the Tigertronics unit into your USB port and use it.
It should work automatically, or according to the operating instructions.
