Good evening where ever you are in the small world? Hi hi. Boise, Idaho. Home of the Dropping Potato!
I have a new to me SB200 I recvd about 60 days ago. I'm just now getting ahead of upgrading/repairing this unit. SB200
Pics
https://www.qsl.net/kd7tww/SB200/MY main reason here & question is? I've done as much as what was recommend by my other Hams and my own personal experience which is not much on RF Equipment and online? But I do have a pretty good understanding of electronics and learning as I go about HV amplifier units like this and slimmer ones. So Right from Wrong works well with me in my head for repairs. I don't botch, Hi Hi.
I could never afford something this nice in my lifetime. I am a General btw. I am hoping to learn more about HF amplifiers. And I'm on the lookout for another BONE stock unit, BTW.
Hoo hoo. What's been done so far:
1. Upgrade p/s. Increased Capacitor Quaintly to 8 KEMET 270uF 450 caps. I've never seen 6 Original Equipment caps get so bad and dried out My thoughts are with 120v service and portable Operations with a Chinese gen set. This unit will be my portable rig only. I like the lower bands, 10m and 2 meters. Tubes as I was told only had a few hours of service (572B) I have yet to test those pair still.
2. 6x 100K 5W Bleeders. 4 were shot, 2 open
3. 16x 1n5408. Saved 2 old for the front meter
4. Put 2 cross diodes on the meter circuit
5. Added a slow turn on circuit with a front mounted toggle bypass switch. 2x 25 ohm 25 watt Ceramic wire wound resistors. Wired 120v after the push button fuses. I live in an apt
6. Harabach Softkey SK-201 tested and works
7. Removed the PT HV Transformer out and installed 2 sleeves of High Temp Heat shrink tubing to the HV leads and Grn Fillment leads. Sealed up PT with Hot (chinese snot) Glue. Delicate cloth wires will never fray again.
8. R&R 2 mfd and 20 mfd caps
9. Back of Chassis R&R R21 and R22. Out of Tol
10. Re-added one each .02 1kv caps to the Ant and Alc. They where removed for some reason??
11. Added a cool mod. A Push-Pull 100k Lin 6mm shaft, for the SWR pot (r13). So I can disengage amplifier (Pull2 bypass switch) when I want to go 100 watts and a wire or QRP? Pull to disengage. Pot was Pricey $$$ &X&X^&..!
12. Replaced many wire(s) and solder wicked wiring. R&R HV cable to a high grade 10 KV cable.
13. New Parasitic suppressors, 100 puff c26 blocking cap. It was cooked, checked open.
14. Front meter sticks. Moves slowly?
15. R&R Original fan and motor. Replaced with a Bathroom plastic bladed fan and motor. It's works okay but not great (wanted to try it). I'll update as I go along. Thanks so far. 73, Vince
P.S Am I missing something here? Hey Heathkit Gurus
https://www.qsl.net/k/kd7tww//Canadas%20New%20Class%20of%20Amateur%20Radio%20License.html
